Old 05-26-2017, 04:45 PM
Oli P Oli P is offline
Default Re: Tracks out of sync AFTER recording
Did any of you happen to use the Audified u73b compressor in the session where the audio shifted?
It happens to me quite a lot if I have one of those instantiated and start recording. The audio gets shifted ahead by around 40-50 ms
If I take the u73b out or make inactive, the problem goes away.
www.olipoulsen.com
iMac27 i9 3.6 (late 2019) / 64 GB Ram / OS 10.15.7
Apollo 8 / PT Ultimate 2020.9.1
Old 06-15-2017, 01:33 AM
Thevexproject Thevexproject is offline
I am dealing with and have been dealing with this issue for some time now. I will record something (using a Tascam us-1200 [usb] into pro tools 12) and as I'm sitting there i can visibly see the audio being written early. I spoke with a college on the topic and he found his daw (logic) has some time displacement on which he turned off and it fixed it for him. Is there anything in pro tools that would cause this, i am getting quite annoyed at having to slide my clips right a 64th note.
Old 06-15-2017, 04:32 AM
Actionmusic Actionmusic is offline
I haven't seen this for a while but on some versions of PT if your workflow includes duplicating tracks , say copying your vocal track with it's plugin setup to create a new track to record on, this could cause some problems with out of time recordings.
Old 06-15-2017, 10:52 AM
I'd be happy to make a recording of exactly what I'm experiencing, that would probably help.
Old 06-15-2017, 12:25 PM
https://youtu.be/H-1PKD2IAbo
Here is my issue. It's placing my recording early as i track it. Which of course is a big issue for me.
  #16
Old 05-11-2018, 09:24 AM
slashy's Avatar
slashy slashy is offline
I have actually the same problem with pro tools ultimate.
After recording the clip is on place but not the wave inside it. It begin sooner than I recored.
I have no solution, I tried many things, but without result.
Please, could you help me ? I become mad
  #17
Old 05-11-2018, 10:14 AM
The Weed's Avatar
The Weed The Weed is offline
If the clip is in the right place, but the wave inside it isn't, see if you can move the wave within the clip. Look in the Reference Manual for how to do that.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
  #18
Old 05-11-2018, 03:42 PM
PierrevC PierrevC is offline
I've had sort of this issue when rerecording.
One of my stems track had an offset.
I didn't try to spot it as it was not usable and I'm recording in Destructive mode so the sound was shifted from my inpoint.
I thought delay compensation was not correct...
It happened after I had a "could not get audio fast enough error".
First few times I restarted PT but then I found that if I switch the buffer size back and forth in the playback engine it's ok again.
I'm on 2018.4 HDX mac pro mid 2012, high sierra and very heavy session.
iSeeSound.be | Audio Post Production
  #19
Old 05-12-2018, 05:41 AM
slashy's Avatar
I try this, but no issue for me.
This afternoon, i will try again, but i become mad with this problem.
  #20
Old 06-03-2018, 10:34 AM
slashy's Avatar
I have always the same problem, the wave is sooner on the grid after recording ....
Is anybody have a solution , please ?
Recording through plugin on aux tracks bussed to audio tracks Tonepicker Pro Tools 12 11 07-13-2016 09:26 PM
Tracks/voices losing sync during playback/recording bobbyskeg Pro Tools TDM Systems (Win) 1 05-20-2011 02:57 AM
Stereo tracks recording out of sync Neveguy Pro Tools TDM Systems (Mac) 2 01-29-2006 09:22 PM
sync midi drum tracks to wav tracks Adrian D 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-14-2003 12:24 AM
How Do I Sync Midi Tracks and Audio Tracks Antonio Tarantino 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-11-2003 05:49 PM
