  #101
Old 08-06-2011, 04:28 AM
Default Re: Equality for all post mixers
Lots of AS plugins do not report the delay compensation correctly to PT. I first noticed this with NoNoise many years ago but there are many more.
Also Transmod was famous for this.
I read somewhere that this is due to programming error of each individual plug-in that fail to report their delay to PT.
frank.
  #102
Old 08-06-2011, 09:30 PM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
Thanks Frank
  #103
Old 08-19-2011, 03:26 AM
DaveGamble DaveGamble is offline
DMGAudio
EQuality v1.15 update out now :)
Changes:
- CPU Usage Improvements
- Added ProTools metering support
- Fix M/S / bypass latency for non-8k IR length.
- Added analyser outlined/filled/both pref.
Grab it from dmgaudio.com under Downloads on the EQuality page :)
Dave.
  #104
Old 08-19-2011, 08:28 AM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
Any planes for TDM support?
Also can you please fix the bug when the EQuality was overloaded (clipped) by one of the band excessive gain amount, there is no way to remove this clipping indication (opt+c) doesn't work. It removes it for a second and then just back.
Removing and inserting the plug solves it.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3
MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM
MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24
HTML code is On
Avid Giving Protools Post Audio Mixers the FINGER!!! bloke Post - Surround - Video 18 08-27-2013 07:26 AM
Equality and PT10 HD digidub Post - Surround - Video 5 01-03-2013 03:17 PM
Changing Equality parameters causes PT 10.2 to crash garnoil Post - Surround - Video 3 07-06-2012 10:51 AM
DMG EQuality with D-Command ChrisBurdon Pro Tools TDM Systems (Mac) 0 02-07-2012 12:26 AM
Equality strange problem garnoil Post - Surround - Video 3 01-14-2011 12:14 PM
