Pro Tools 8 Not Recognizing Reason 4
I don't know too many tricks. i've had Reason for a while and have used it just fine. I create an aux track, open an insert. go to instrument, and there is Reason. That's not the case now. My controller works with Reason, but I can't get it to come out of PT. These plugins are frustrating. I think I'll just go buy all of the analog instruments Reason is modeled after and then get an SSL board to run everything out of. That should work. But while I'm saving up the 500K to buy all that stuff, can someone please help me get Reason up and running?
Many thanks. |
Re: Pro Tools 8 Not Recognizing Reason 4
Try this:
If that didn't work, try re-installing reason & going through the steps again. |
I have same problem. The point for me is to be able to open Reason as an insert on an AUX track, not as a Pro Tools Instrument track. When I load is as an instrument track I can no longer record MIDI into Reason...it goes into Pro Tools, and I don't want it to.
I used Reason as an plugin on an AUX track within Pro Tools for years. Why is it now all of a sudden not working? |
Pro tools not recognizing hardware | wgouldsby | General Discussion | 3 | 12-08-2013 06:24 PM |
PT8 not recognizing Reason | treymix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-06-2009 02:23 AM |
pro tools not recognizing mbox | chunkymutt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-24-2009 08:48 AM |
2 Problems: PT not recognizing plug-in and CPU not recognizing external hard drives | jasonguitar | Pro Tools M-Powered (Win) | 0 | 06-28-2009 06:32 AM |
PT isn't recognizing Reason and BFD | felmonk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-19-2007 01:12 AM |
