how do u assign midi conrtoller to plugin parameter?
I have a controller keyboard with those midi programmble controller knobs. How do I go about assigning it to a plugin parameter? or virtual synth ie virus?
Re: how do u assign midi conrtoller to plugin parameter?
Although I don't think that you will be able to control parameters of the Virus plug-in, you can define the knobs on your Controller to that of a standard MIDI Control Surface Profile (such as the CS10)...this information is available in Appendix A of the MIDI Control Surfaces Guide.
-You can then set Pro Tools to "see" the standard controller in the Peripherals dialog, and Pro Tools will follow the incoming MIDI data from the knob(s). Brent |
You can control the Virus in the same way as a hui does however because there is no way of knowing which knob does what it then becomes slightly confusing. Ihe way i have done it using my K2600 is to find out which control numbers are needed for the faders, plugins and bank switches this is all i set up will post the numbers when i get home (at work at the moment).
MIDI / Plugin parameter question | Hawk570 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-09-2010 08:56 AM |
How to assign a fader to automate a plugin parameter?? | teacherman | ICON & C|24 | 5 | 03-04-2009 11:59 AM |
how to assign a plugin to a midi track | shoog | MIDI | 3 | 12-01-2007 07:50 AM |
003 Console displays no plugin parameter | apfel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 09-12-2007 03:10 AM |
How to assign MIDI CC to plugin parameters if no MIDI Learn? | Mitch Manger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-25-2007 11:10 AM |
