888/24 in Standalone mode
a friend who was using pt|mix just got an 003 and an imac because he couldn't stand how slow the g4 was. But first thing he discovered the 888/24 sounds better than the 003..he asked me if he can link the 003 to the 888/24.
I know 888/24 can be in standalone mode, but it doesn't seem it can do AD/DA simultaneously. According to Digi, To use your 888/24 as a stand alone' 24 bit Analog-Digital or Digital-Analog converter:
??? Anyone know more ? Jantzen
Mac Pro 8-core 2.8GHz Pro Tools 10 HD |
Re: 888/24 in Standalone mode
888|24 and LE hardware do not work very well together, because the mix flagship outputs AES or SPDIF and LE hardware only has two channels of SPDIF i/o (plus optical ADAT which the 888 does not have).
I'm just wishing to use two channels of conversion, but it doesn't state whether in standalone mode it can function both ways. Will it be happy taking a clock form the 003? (easiest)
Jantzen
Now I must say I don't know for sure. Usually digital devices are able to lock to whatever digital input they are fed, but this time... not worth it. 888|24 converters are not that much better than 003, and IMO 003 converters outperform the Mix hardware when clocked at 96k which the legacy hardware cannot do. And I'm not sure the 888 sounds any better if it would be clocked to LE hardware to begin with!
If you need to get better DA converters for LE system, I'd recommend an Apogee Rosetta 200 for DA converter and clock master.
sure it does in the very first post stand alone' 24 bit Analog-Digital or Digital-Analog converter
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
002 standalone mode | alon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-06-2013 06:14 PM |
Standalone mode? | Plectrum | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-09-2005 12:17 AM |
888 Standalone mode | Siegfried Meier | Pro Tools TDM Systems (Mac) | 1 | 06-11-2004 02:20 AM |
Studio 882 I/O in standalone mode ? | nymo | Digidesign Hardware & Software | 0 | 04-10-2003 03:51 PM |
002 standalone mode | davip | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-31-2002 05:17 PM |
