Hide and Show tracks bug
I have been having problems with the show/hide tracks list. I will shift/click select several tracks then go for another and the GUI refuses to select anything new. Then, inexplicably, the track is selected and all other track selections are lost. Or, many (or all) tracks are selected and I try to deselect a track and it won't work.
I did some homework and found a show/hide "delay" problem described on another thread, but not a thread that specifically addressed this issue. Any suggestions? G5 Dual 2.0 GHZ (gen II)/2.5GB RAM OS 10.3.7 PT 6.7cs8 Accel 3 |
Re: Hide and Show tracks bug
anyone home?
The same happens to me when selecting regions with the object grabber. And I remember seeing the problem like you explain it, but it seems like a bug.
bump
Is anyone home?
Ray -
I'm unable to duplicate the problem you're describing. You shouldn't need to hold 'shift' to select additional tracks - just click on the tracks you want to show/hide and it will change the state of the track. If you are describing something other than this, please explain further. If the behaviour of your system has changed, try trashing prefs to see if that restores normal behaviour. |
It seems I have used a Mac convention of shift-click to show my tracks intention when all along it has been sufficient that a single click would have been most proficient So now I will simply click my track status And learn a lesson from an expert for gratis No false report, no bug should be claimed When it is I myself who should be properly trained |
Show/Hide Tracks | blastula | Pro Tools TDM Systems (Mac) | 13 | 05-30-2010 02:14 PM |
Show/Hide multiple tracks? | syd | Tips & Tricks | 5 | 01-12-2007 01:49 PM |
difficulty with show/hide tracks selecting | Neale Eckstein | Pro Tools TDM Systems (Mac) | 1 | 05-07-2005 01:28 PM |
Show hide Tracks | ZEUSS | Pro Tools TDM Systems (Mac) | 3 | 07-03-2004 09:11 AM |
Secrets of the Show/Hide tracks list | Fave | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 05-27-2002 09:47 PM |
