Old 03-10-2012, 10:01 PM
MidnightFlyer MidnightFlyer is offline
Default Midi to USB adapter
I'm using an M-Audio Keyrig 49 as my USB controller to do pianos and virtual instruments.
But I'm curious if I can use my 88-key Casio Privia keyboard, with real piano action, and use the midi-out on the side, with a USB adapter, that would allow me to go into my Imac using the USB port, as I do with my Keyrig 49, and use the Casio instead of the Keyrig.
I'm just not sure the steps I would need to go through. And how would I get Pro Tools to recognize it? Would I need to install drivers or anything complicated like that?
Old 03-11-2012, 10:00 AM
nst7 nst7 is offline
Default Re: Midi to USB adapter
You can definitely do this. The M-Audio Uno is a good choice. It will work the same way as your Keyrig, in that it should be automatically recognized on the Mac. If not, go under Utilities>Audio Midi Setup, and click "Rescan Devices" and it should be recognized.
Alternatively, you could also look into a keyboard controller that also functions as a Midi to USB interface, such as any of the Axiom series (including the 1st generation ones, if you find one used).
Old 03-11-2012, 09:32 PM
AfterJohn AfterJohn is offline
+1 on the M-Audio Uno
I use one, have used it on dozens of systems too with no problems.
MacBook Pro 2.2 GHz Core i7 4GB RAM 10.8.5, PT 10.3.4, Waves v9.1, Duet 2
redtuxedo.com
milkmoneyconsulting.com
mindexpansiontechnology.com
VST to RTAS Adapter: Usable on non-MIDI tracks? Kryst 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-15-2006 03:53 PM
ADC to VGA adapter iamspooky 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-07-2002 12:00 AM
What midi adapter to buy? Voideco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 09-22-2001 10:18 AM
Midi "Y" Adapter? trackfive 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-04-2001 03:13 PM
Keyspan USB Serial Adapter & Midi Timepiece Av O.D. Pro Tools TDM Systems (Mac) 0 11-14-1999 11:28 PM
