Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 11-17-2014, 08:36 AM
goodness goodness is offline
Default Sync Alesis HR-16 w/Pro Tools as Click
Hello All,
I am new to the forum so not sure I'm posting this in the right place.
I am a professional studio musician (drummer). I want to use my Alesis HR-16 as a click track and have the tempo driven from Pro Tools.
I've done this many times in the past but I don't know exactly how the engineer went about setting it up.
The studio I am going to do this in is running an older version of Pro Tools (8.2 I believe) on a Windows machine. I'm trying to find some instructions that I can share with my engineer buddy so we can get this working.
The built-in click in PT is not exactly musical. I program simple percussion patterns in the HR-16 to use as clicks. However, it's always been my understanding that the clock in the HR-16 is not as accurate as it should be. So, engineers I have worked with in the past drove the HR-16 from the Pro Tools clock.
I see in the HR-16 manual that the clock can be set to either MIDI & INTERNAL (default), INTERNAL ONLY, or TAPE SYNC IN.
I hope that makes sense.
Thanks in advance for any help/advice anyone can give me.
Old 11-17-2014, 12:45 PM
Default Re: Sync Alesis HR-16 w/Pro Tools as Click
Actually, this is a lot of work that is counter-productive to a certain degree. As for making it work, it SHOULD be as simple as feeding MIDI from the session and to the HR-16 and setting the HR-16 to slave to incoming midi.
Having said that, is there a reason to NOT use the click function that is part of PT? I provide click for all of my projects and have not had any issues
Old 11-17-2014, 01:16 PM
albee1952/Dave - Thanks so much for taking the time to respond.
I realize that PT will put out a click. However it is pretty sterile sounding (not musical at all).
I spent many years as a session player in Nashville (I see that's actually where you are) and the click was always a drum machine synced with the PT clock. It's a much more musical approach and what I'm used to.
The problem is, all I every had to do was program a pattern in my HR-16 and the engineer did the rest. So, I don't know exactly how to make it work.
Now I'm trying to duplicate that process for a friend in his home studio. That's why I'm looking for some instructions that (between the 2 of us) will help get this working.
Thanks again!
Old 11-17-2014, 04:45 PM
I see. Any time my players despise the stock click(and I do agree that it happens), I generally toss up EZdrummer or SD2 with a percussion loop. Since I run 5 discreet stereo phones mixes here, usually giving the drummer all he wants(waaaay more than anybody else) and just a bit to the other players seems to hit the "sweet spot" for tracking BTW, its possible to use the stock click to send midi to a VI plugin, which opens you up to tons of sound choices
Old 11-18-2014, 05:15 AM
Dave - I normally run a More-Me box - sending the HR-16 directly into my More-Me as well as to the control room. That way I can adjust the level of the click independent of the overall mix. With 5 channels, the click could easily be in one of the five, allowing for the same control.
Alesis AI3 won't sync w/002r qbert1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-09-2005 06:01 PM
alesis qs 6 and 001- click problems- HELPPPPPPPPPP hitwriter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-18-2005 10:52 AM
Video Sync PT LE + Alesis AI2 DodgyDave 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-23-2002 04:02 AM
Alesis Masterlink to 001 sync? Machead 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-01-2002 03:52 PM
001 and smpte sync w/ Alesis AI-2?? jeffredefer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-27-2001 07:03 AM
