Copy automation to different parameter for same track
How do you copy automation from one parameter within a track to another, within the same track?
For example, if I want to have a send for both delay and reverb follow the same pattern, how would I just copy the pattern for one to the other? I know you can copy automation from one track to another, or within the same parameter, but I haven't been able to do it when copying from one parameter to another parameter within the same track. |
Re: Copy automation to different parameter for same track
IIRC, Paste>Special.
When I try that, it seems to paste only within the same automation parameter.
Use control-cmd-v instead of cmd-v.
Copy plug-in automation to inactive track | simonchase | Pro Tools 12 | 4 | 11-20-2017 04:06 AM |
PT Asks To Enable Automation for Every VI Parameter When Copying Clip to Other Track | jrgillam | Pro Tools 12 | 3 | 08-31-2016 12:10 AM |
Copy Audio Track Automation to Midi track controller (Mod Wheel) | cybercampbell | macOS | 3 | 05-11-2013 10:18 AM |
Anyway to copy plug in automation of a selection from track to track? | emilano | Pro Tools 10 | 5 | 04-09-2012 09:28 AM |
can you not copy automation data from a mono track to a stereo track? | Felix | Tips & Tricks | 5 | 04-09-2002 06:32 PM |
