Old 05-29-2018, 03:08 PM
Ray Lyon Ray Lyon is offline
Default Xpand FX2 send on C channel goes bonkers
Hello to all Xpand2 users,
I'm creating a stacked sound in Xpand 2. In the Part C section (part 3) no matter what patch is loaded the FX2 knob jumps erratically to different levels randomly while the track is playing .
I have checked the FX2 automation parameter and even though there are no parameters or automation written on the track the automated send level level jumps around for no reason.
This happens when the automation mode selector is off or in read mode.
I tried to override it by setting 0 volume parameter automation for FX2 Send.
The send still jumps around but this time in beat with the music.
Does anybody have a clue?
Am using Xpand 2.2.1.18799 with system as specced below.
Thank you for your assistance.
Old 05-30-2018, 12:00 AM
chrisdee's Avatar
chrisdee chrisdee is offline
Default Re: Xpand FX2 send on C channel goes bonkers
If there is some level automation going on have you checked through all the different volume/velocity categories?
Do you have a midi keyboard? Maby try disconnection that to se if it's sending some volume/level signals.
Old 06-06-2018, 01:07 PM
I found the culprit... went to MIDI event list and found an "undefined" parameter controller value of 88 which had somehow recorded itself onto the part. Selected and deleted the spurious data and I'm good to go. It was eating tons of MIDI bandwidth. Have no idea what caused it.
Thx for your suggestion...
Flipping level and send of the same channel? Frank Kruse Artist Series 1 05-30-2014 11:11 AM
Insert/Send selection from the Channel Matrix Jed27 ProControl, Control|24, Command|8 0 05-15-2009 11:43 AM
Send pan is grayed and following the channel pan... cuzinofdef Pro Tools TDM Systems (Mac) 2 05-24-2007 02:38 PM
Link send pan to follow channel pan? gchang Post - Surround - Video 9 06-17-2006 12:32 PM
Audio channel as an fx send? any reason not to? crizdee Pro Tools TDM Systems (Mac) 1 04-27-2005 07:46 AM
