Old 09-15-2015, 02:56 PM
channaD channaD is offline
Default Artist Mix and Transport not showing up EuCon 3.3.1
Hi!
As the title reads, I don't see the control surfaces in EuControl, and yes, it does not work. I just downloaded 3.3.1 and it said I have to update my firmware. Great! I'd love to...but the surfaces do not show up. So they are now just expensive paper wweights taking up valuable desktop space.
Someone out there that can help me?
OS X 10.9.5 is what I'm running. The surfaces don't register in EuControl at all. I can't get this thing working, and why should I have to pay $59 to contact support? It seems ridiculous that AVID won't just have levels of support. This is basic support that should be free with a new version update.
Any help would be greatly appreciated! Thanks!
Old 09-15-2015, 03:25 PM
mrtomcat mrtomcat is offline
Default Re: Artist Mix and Transport not showing up EuCon 3.3.1
a few possibles:
Unit is off
Ethernet cable is not connected
Network is down
if none of that is true
reset Artist Mix DHCP to renew the IP lease
if that doesn't work contact support
My bet is that you need to renew the IP lease
Mixing/Producing/Recording
PT Ultimate 2019.5
Wavelab Pro 9.5
UAD Satellite Octo Thunderbolt,
Apollo Twin Duo,
HDX Card running in Sonnet TB3 expansion box,
2x Avid I/O Analog 16/16,
4x Artist Mix, Avid Dock, PT Control,
Mac Mini 2018 32gig ram 1 TB SSD 6 Core running Mojave,
lots of outboard gear
Old 09-15-2015, 04:04 PM
Southsidemusic's Avatar
What tomcat asks above and also how are your units connected to the computer? Switch/Hub or modem etc??
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 09-15-2015, 05:46 PM
I see what you're saying on all those points. The thing is, the artist mix and transport both work fine on my laptop. I just got a new desktop, and it's just not working right.
Laptop:
MacBook Pro OS X 10.8.5
EuControl version 3.2.1
both units are connected to an ethernet hub, then to laptop.
both units firmware are up to date for EuControl 3.2.1
Desktop:
Mac Mini OS X 10.9.5
EuControl 3.3.1
both units do not show up in EuControl under surfaces, and I can't update the firmware if I wanted to.
Both units are still connected the same way as laptop, but just connected to the mac mini from the hub.
Both units work fine on the laptop, but do not show up at all on the mac mini. I just got the mac mini 2 weeks ago, and this is the final step in getting the studio up and running. It's super frustrating, especially having to pay for support, when this is clearly related to the update.
I even tried installing EuControl 3.2.2 which was the first to have support for 10.9.5. Should I try installing an older version of EuControl?
Old 09-15-2015, 05:51 PM
To me it sounds like there is something with your ethernet settings as this works for others and if it was a bug issue more people would complain so what does your ip settings say and in the Eucon app there is a setting for either WiFi or Ethernet which needs to be set to Ethernet and Not Wifi as it wont see the units otherwise. We did that same headspinn before we found the setting had changed itself to WiFi instead
Best Regards
Christopher
WEBHOME
Old 09-15-2015, 05:54 PM
yep, the ethernet vs wifi setting. Also check if you have your firewall enabled on the mac mini, it might be blocking the artist boxes.
PT Ultimate 2019.5
Wavelab Pro 9.5
Apollo Twin Duo,
Old 09-18-2015, 10:47 AM
Hey guys, I'm really havnig trouble finding where this wifi vs ethernet setting is located.
I don't see it in Surfaces, Workstations, General, Preferences, Assign, Layouts, or Softkeys.
If I change the service order on the network preferences in the mac mini, I then can't get on the internet through wifi.
This is very strange...
Old 09-18-2015, 10:53 AM
That setting is under Eucon network settings i want to remember. Not in Eucon menu.
There is a choice to change settings in the Eucon Network setup where there is a VERY small lane where you choose wifi or ethernet in that window.
If you dont don't find it i will check as soon as i am back in the studio if no one else chimes in and point you to where it is.
Best Regards
Christopher
WEBHOME
Old 09-18-2015, 01:52 PM
Okay, I've found the setting. It's in the System Preferences, then EuCon, and then I see the setting.
It's already set to ethernet.
Old 09-18-2015, 02:02 PM
Alright! Looks like I got it! You guys were right all along.
I did need to assign a static IP address.
Thank you guys so much!! You've been very helpful...
now I'm on to my other dilemma...do I sell the Artist Transport?? I don't' really use it that much. Still using the number pad of my keyboard.
Any thoughts as to why I should keep it?
Bug for Artist Transport since EuCon 3 Voyageur Artist Series 5 08-04-2016 11:58 PM
Artist Transport and Eucon 3.2.2 Crashes PT11.3.1 siann1 Artist Series 6 01-24-2016 11:04 AM
Touching Artist Transport Freezes Up Artist Control in Logic sonofmack Artist Series 1 03-13-2013 08:22 PM
ARTIST TRANSPORT: Transport knobs do not light up when pushed smallchamber Artist Series 0 02-26-2013 05:36 AM
Artist Transport and EuCon - what am I doing wrong? ArKay99 Artist Series 4 11-08-2012 08:50 PM
