Old 05-28-2014, 04:47 AM
serstickman serstickman is offline
Default Considering move to PT 11
Been holding off on upgrading from 10 to 11 for a good while now. I read about all the folks posting in here having issues which I don't doubt they are having and I wonder, "Should I do this?"
Yet, I speak with other folks who can't say enough good things about working in PT 11 who are making their living using it. I get all fired up again. Start watching tutorials and feeling like my workflow in general is going to be improved.
Any suggestions or explanations for the disconnect between those having serious issues and those having none?
Thanks for the time.
Peace
PT 12.5.1, Reaper, S1, Cubase, Logic 9 & X, Mac Pro 4,1>5,1 Yosemite 10.10.5
Old 05-28-2014, 05:02 AM
sw rec sw rec is offline
Default Re: Considering move to PT 11
Kudos to AVID for allowing PT 10 and PT 11 on the same system. I waited quite awhile to go with 10 from 8 (never did use PT 9), then installed PT 11 so I could work out the bugs, all the while getting my actual work done on 10. The one show stopper for which I found a solution here on the DUC was the need to disable the floppy controller, even though there was no floppy drive or even a port on the MOBO for one. It wasn't an issue in PT 10 but it brought 11 to its knees! The other holdout at the time was a time lag for AAX plugin development, but at this point, 99% of my "go to" plugins have made the AAX transition, and I rarely use 10 anymore. I appreciate being able to make the transition gradually. All is well here with PT 11/Win 7.
Old 05-28-2014, 05:25 AM
Njal Frode Lie Njal Frode Lie is offline
Well, I waited until now, and did a dual install before I was about to start on mixing an album for a customer, as I thought I might finish other projects in 10 and use 11 for this one from the start.
You know: 'Never upgrade while in a project' kind of thinking...
After some testing out, I had to go back to PT 10 for the album-mixing, since PT 11 was unusable for me. (on Win7 platform).
The showstopper for me was that Space reverb didn't keep it's settings.
Very annoying, and I wasn't able to find a way past this, and I like and use Space reverb a lot.
In addition it seemed a bit unstable too, I had a couple of freezes.
So, back on 10 here now, and it's rock stable and does everything I want, expect perhaps for the offline bounce... I was thinking it would save some times for me in the end of this album mixing, but perhaps in some months time on another project...
NF
Peace
Old 05-28-2014, 07:18 AM
joachim's Avatar
joachim joachim is offline
..., and I wasn't able to find a way past this, ...
Did you automate the settings of Space ? Then they should stick.
PT 11.3.1 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 64GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 05-28-2014, 08:00 AM
No, didn't try that at the time.
Read about it later though, and it looks like this work for some, and not for some others.
And, also, I was thinking that if this was broken there would probably be other things too, not working.
So staying at 10 a little longer (although I did buy 11).
So how's your system going, joachim, no problems?
All plugins keeping their settings, and no problems with bouncing or delay compensation?
Old 05-28-2014, 08:22 AM
TOM@METRO's Avatar
We are exclusively on 11, and have been for a couple of months now since removing 10 from our production drives. There is no desire here to go back. A number of our sessions will no longer run on 10 do to the VI RAM demand.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2019.5 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 05-28-2014, 08:38 AM
By the way, just in case I want to test again;
- any quick non-HD way of writing all plugins parameters to all tracks?
NF
Old 05-28-2014, 08:53 AM
YYR123's Avatar
YYR123 YYR123 is offline
NF
Same here, shame we should see more of this. If you have issues fallback
Daniel
Old 05-28-2014, 09:29 AM
joachim's Avatar
NF
This might apply : Storing an Initial Control Position (PT 11 Ref Guide, p.999)
Basically :
Automation enable all parameters of the plugins
Automation window : only Plug In selected
Automation Mode to Read
Playback, move all controls of all plugins to the desired position
Stop, go to start of session
Automation Mode to Write
Playback some seconds in Write.
This works, if there are no breakpoints for the plugin parameters except the very first one yet on the tracks.
And I would test this first on a copy of the session.
Old 05-28-2014, 09:43 AM
Hi joachim, and thanks for this.
Unfortunately I don't think this will work for my problem, here's more details:
I did a mix of a song for a band, in PT 10, they liked the mix and I got the mixing of the whole album.
I tried to make that PT 10 mix work in PT 11, but it doesn't.
The Space plugin (and maybe others) loose their settings as soon as I hit play, or maybe as soon as I load the session (can't remember at the moment).
Now I am almost done mixing all songs, mixed in PT 10, and still I would probably save a bit time for the mixes and updates, if I had off-line bounce.
But then I would need to have PT 11 play the mixes as PT 10 did, and not loose settings while I load it or hit play.
Still, thanks for your suggestions, as this might work if I start a new session in PT 11, and not having to be able to play a session made in PT 10.
NF
Basically :
Move the red diamond in the tempo bar in the edit window, only some tracks move kingheartless macOS 2 02-21-2013 03:20 PM
move up to HD? Filmusic Windows 9 12-15-2010 03:03 PM
is it safe to move to move to SL ilulilu888 Pro Tools TDM Systems (Mac) 10 12-05-2010 10:23 AM
Can I move regions and have the underlying playlists move also? smpkeys Pro Tools TDM Systems (Mac) 4 02-18-2010 07:30 AM
My next move/What to buy? David Fisher 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 18 08-01-2002 12:55 AM
