Old 02-13-2005, 09:21 AM
deejfro deejfro is offline
Default How do you make a reverse reverb effect?
Is there a plug in that will do this?
the only way i can think of by recording the reverb to an audio track the reversing the region. Is this correct? any other suggestions?
thanks
Old 02-13-2005, 09:35 AM
SimpleNatureSpirit SimpleNatureSpirit is offline
Default Re: How do you make a reverse reverb effect?
Many plugin and hardware reverbs have reverse settings.
This simply makes the verb louder as time goes on.
Unfortunately, D-Verb doesn't have this.
I doubt that you create an effective simulation of this.
If you like verbs in your works, consider buying a real reverb plugin.
If you only need this for a very select session, play with the DigiRack's Delays.
The feedback setting will let you do something like what you're looking for.
Then send that signal into D-Verb to smooth out the effect.
Just mix the source material back into the effect and watch your latency and make up for the initial delay.
Share the gift gifted to you
Old 02-13-2005, 09:24 PM
Shan's Avatar
Shan Shan is offline
thanks
I like to do it the old fashion way like Charles Dye does here.
Hope that helps.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Can I Add a Reverse Effect on Midi (Drums in Xpand) gavriil1 Pro Tools 10 4 11-28-2012 06:27 PM
reverse effect idea? nucelar Post - Surround - Video 8 07-07-2009 12:01 AM
reverse reverb effect SublimeAndy Tips & Tricks 4 04-12-2008 01:50 PM
having trouble doing reverse vocal swell effect Siberian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-06-2003 07:53 AM
Reverse Reverb for Ld Vox Armando Pro Tools TDM Systems (Mac) 5 11-13-2001 09:02 PM
