Old 11-18-2003, 05:41 PM
philper philper is offline
Default OMF export from ProTools 6
How exactly does one export a PT 6 session as OMF using DT2? I can't find anything that seems to work in the software, and the manual wasn't very helpful. When I tried "publish as OMF" I got a 2 tr. mix.
Philip Perkins
Old 11-18-2003, 05:59 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Default Re: OMF export from ProTools 6
On a Mac In Protools
FILE-> Export selcted tracks as OMF/AAF
It seems you are using the bounce to disk option with publish, which will only create a stereo pair or 2 monoss.
IMDB
IMDB
Old 11-21-2003, 01:55 PM
Rick Sanchez Rick Sanchez is offline
Highlite the tracks you want to export then go to the file menu and select export selected tracks as OMF. It will then give you the options for SDII, AIFC, Embedded, Sample Rate, Enforce Avid Compatibility, etc.
What are you sending the OMF file to? I have to export to both ABVB and Meridien Avids as well as DV express. Final Cut Pro will not yet import OMF. Depending on what system you are sending the OMF to does make a difference on the options you choose.
Rick Sanchez
http://www.posthastemedia.com
MacPro 2x2.66 GHz Dual Core "WoodCrest"
Mac OSX 10.5.8 / 4 Gig Ram
ProTools 8.0.4
Digidesign/Magma PE6NE-I upgraded 6 slot expansion chassis. (Host card in Slot 2 of MacPro)
HD3 Accel
BlackMagic Decklink Studio 2 (In Slot 3 of MacPro)
SurCode / Dolby Media Meter 2
Izotope RX2 Advanced / Sonic NoNoise
Waves Platinum 7.x / Serato PitchnTime
Melodyne Studio / Altiverb XL / Speakerphone
KOMPLETE 7
EQuality / Massey L2007
TC MasterX
HTML code is On
protools OMF export therecordinghouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-31-2008 05:57 PM
FCP export to Protools cpierson Post - Surround - Video 4 04-13-2006 04:12 PM
Protools AAF export MattV Post - Surround - Video 8 08-28-2004 05:48 AM
protools export to final cut? anders Post - Surround - Video 2 04-27-2003 07:25 PM
Multichannel export from ProTools sburgess Pro Tools TDM Systems (Mac) 1 07-20-2000 12:10 AM
