Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 07-25-2015, 06:41 PM
AhwatukeeComputerRepair AhwatukeeComputerRepair is offline
Default Re: monitors vs. headphones
You can mix with headphones as long as you know what you need to compensate for. While ideally you want monitors for a true reference headphones can be used if monitors are not available.
One thing to look for if you're going to purchase headphones is to make sure they are flat frequency and not boosting the low end or the highs. For example don't buy Beats and expect to mix since they have a boost in the lows and really are not good for giving you a true sound.
Old 07-25-2015, 06:54 PM
You can make it easier on yourself to mix on headphones if you use headphones with a cross feed circuit. Such as Meier Audio provides in their headphone amps. http://www.meier-audio.homepage.t-online.de/ Grace Design was licensing Meier's cross-feed technology for their monitoring products (http://www.gracedesign.com/products/...ntrollers.html) but it looks like may have gone with their own xfeed technology with current products. Either way headphone amp/monitoring products from both companies are *very* impressive. And yes obviosuly you are goign to work as well on a variety of monitors for critical stuff.
Flipping between different cross-feed levels and turning it off entirely (so you what what an average consumer will hear on their headphones) as you check things is a good idea. Personally I just can not listen for long periods of time to a headphone that is not using cross-feed. Far too tiring and distracting, and has the issues that JFreak described well...
Old 07-31-2015, 07:54 PM
Amack Amack is offline
Aren't there any good cross feed plugins?
Old 07-31-2015, 08:33 PM
mesaone mesaone is offline
There are, but they only give an approximation.
Some try to emulate the head-related transfer function but fall flat. The physical interactions between source and space and ears are so complicated, it's understandable when "faking" it doesn't work out.
Amack, have you auditioned Beyerdynamic DT990 Pro headphones? You should. This is as close as you can get to being "in the room" without DSP or special processing.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 08-01-2015, 07:49 AM
mesaone,
I think they would/should give a better approximation than the Meier analog filter/summer approach - and certainly offer more control-ability.
Thanks for the tip on the headphones. At least for now my son seems quite happy with his DT 880 600 Ohm Premiums. They sound pretty good to me too - which apparently doesn't say much. After testing them (and others) at http://www.audiocheck.net/soundtests_headphones.php and doing the hearing tests at http://myhearingtest.net/ it appears that my 63 year old ears likely don't work nearly as well as my 20 year old son's. I'm trying to get him to do the tests too.
As you know, my son is the music guy. I'm just a retired EE that gave up on the "Golden Ear" thing ~ 20 years ago - lucky thing I guess. I prefer quantitative measurement to subjective listening tests whenever possible - especially for electronics/software. Regardless, I started the "DAW System/Subsystem Performance Evaluation" thread showing both approaches - because sound quality matters!
Amack
headphones VS Monitors christophersad Eleven Rack 4 03-14-2013 12:16 AM
No sound out of my monitors or headphones Baumtracks macOS 12 01-11-2011 07:03 PM
How Do I Switch from monitors to headphones?? msurowiec 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 09-23-2006 09:48 AM
monitors and headphones will-i-am 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-07-2004 05:24 PM
Headphones and Monitors ee99ee General Discussion 2 07-27-2003 02:02 PM
