Rogue message from protools on screen
Hi, I have pro tools (8) - and all my audio work is saved on an external hard-drive - and I have just received this message onscreen from Protools LE below.
It reads: This session is saved on a volume set to 'Transfer only' If permitted set the volume(s) in question to 'P' (playback) or 'R' (record) in the workspace. Otherwise choose ok to save a copy of this session and its media to a valid playback volume. The session copy will automatically open from the chosen location. - What i cant understand is: 'This has never happened before (until today) and this message implies I must copy it onto the desktop before i can play it back on Pro-tools' I cant understand this?? -- I even dragged and dropped the song onto a memory stick -- and tried to open the song from there -- and still received the same message. I am hoping this is a generic problem (because I have a lot of songs on there and I am starting to feel nervous). Last edited by jamesleonard; 01-22-2014 at 06:30 AM. |
Re: Rogue message from protools on screen
In Pro Tools, go to the Windows menu and select 'Show Workspace'. In the Workspace window you will see a list of your drives on the left and to the right of each drive will be an 'A'(for Audio) and a 'V'(for Video) column. Under the 'A' column next to your drive it will probably have a 'T'(for Transfer) or 'P'(for Playback) - click on the 'T' or 'P' and, from the drop down list, choose 'Record'.
You should now be able to open, play and record in your session as normal.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
Thanks ...that done the trick! -- I see this problem first appeared 14 years ago and hasn't shown up for 10 years -- any idea on what causes this?
Blue screen crash message with pro tools 8 and M-audio nrv10 | Paul_0165 | Pro Tools M-Powered (Win) | 1 | 06-03-2010 07:58 AM |
Blue screen error message - installing 001 & LE 6.1 on Dell | midnight | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-26-2007 09:20 AM |
Rogue Signal Generator | groovilator | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-28-2005 03:15 AM |
Mbox with Audio Hijack Pro / Rogue Amoeba | Chris Nelson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 08-19-2004 06:52 AM |
blue screen message, btd problem | guy.fi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 03-03-2004 10:16 PM |
