5.1 encoded to stereo audio track - export dts?
I'm hoping someone can answer this real quick for me, can't find much searching... I used SRS Circle Surround encoder and printed a 5.1 concert through it to a stereo audio track. I then cut the contents of the audio track into the individual songs and exported each region. I don't know how pro tools handles the dts information on the stereo track (or if it even know it is there) so my question is: will these files playback in 5.1 once burned to a dvd and played with a proper decoder? Or, should I have done a bounce to disc to get the dts info out of pro tools? Thanks!
Re: 5.1 encoded to stereo audio track - export dts?
You do realise SRS Surround Circle isn't DTS, don't you?
Pro Tools will not accept Dolby Digital or DTS encoded audio. Each track for of the final 5.1 mix has to be exported separately as a discreet track. Dolby Surround/Pro Logic, DTS NEO6 and SRS are matrix systems, where by the surround information is encoded in the stereo track and later decoded back to LCRS or 5.1. DTS (the digital variety) and Dolby Digital keep each surround track independent and heavily compressed, which leads to a better 5.1 sound track, but it can't be played on normal stereo equipment. If you have matrixed 5.1 audio into stereo using SRS surround circle and then edited it in Pro Tools, the encoding will still be there when put through a decoder, as long as you've not done anything to mess about with the phase, as the matrix uses phase differences to know where to place sounds. Quote:
Can't export as stereo interleaved/stereo only multimono? | crizdee | Pro Tools TDM Systems (Mac) | 25 | 10-15-2015 08:41 AM |
On a stereo audio track, the left track is completely dead | ckwhy2008 | Pro Tools M-Powered (Mac) | 1 | 04-09-2011 04:16 AM |
Stereo eq plug in for 2 track audio? | bigb11 | General Discussion | 3 | 03-05-2011 04:09 PM |
Is it possible to Export an Instrument track??? ...not just the audio | hoodio222 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-28-2009 07:24 PM |
Monitoring thru stereo audio track | WRX07 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-01-2007 10:50 PM |
