Timer slower than reality
Hi Guys,
I have a strange bug on my protools 2020. It occurs on two different machines. It seems that the timer is not well setup. When bouncing a song, the duration is always longer than showed in protools (but the speed is unchanged). I have made a quick test to show the issue. I have setup the tempo at 60, 4 beats per measure. So at the end of measure 15, the timer in protools should show exactly 1 minute (because 60 beats of one sec have occured). However the timer show : 0:57.600 If I am bouncing the song from bar 1 to end of 15, the wav and mp3 show a duration of exactly 1minute in Itunes ! So it seems that my timer is totally out ! I'm pretty sure it should be an easy setting. Thanks for your help PS : here is a picture of my protools edit window : https://ibb.co/JFrxWxR |
Re: Timer slower than reality
Clock.
Give details.
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
So I got an Imac 2011 on high Sierra.
My audio interface is an UAD Apollo Quad. The Apollo is set on internal clock, so is Protools. I don't know if there is anything to set aside. Thanks |
Ohhh I found the issue.
By default in pro tools setting I had a Time code Setting up to 4% Film to PAL enabled !! |
Pro Tools Timer | obiwan177 | Tips & Tricks | 3 | 02-04-2010 02:34 PM |
AAF and EDL imports help for first timer | kamshaft | Post - Surround - Video | 5 | 10-20-2009 04:46 AM |
Pro tools should have a timer | uno1234 | Pro Tools TDM Systems (Mac) | 1 | 12-16-2005 10:24 AM |
First timer needs a little help on pc/digi 001 | 69rot | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-06-2002 08:13 PM |
1st timer needs your help-001 w/ mixers,etc. | pelican | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 05-23-2001 08:38 AM |
