Old 11-20-2019, 02:03 PM
Panacci Panacci is offline
Default Re: Bouncing multi tracks (individually?) at the same time
PT has Export as AAF or OMF.
2009,2012 8 Core Mac 5.1, (32 gigs Ram), MSI Radeon 570,s 2011,17 MacBookPros , 828MKIII Hybrid, 828X , 8Pre, OSX Mojave 14.6,High Sierra 13.6, DP11, PT2024.3 , Peak 7, Logic 9 ,WaveLab 11,Cubase Elements 11,Reason 11, DSP-Quattro 5.5 ,many plugins , mics and synths. http://www.panaccimusic.com
Old 11-20-2019, 02:11 PM
amagras amagras is offline
Originally Posted by JFreak View Post
This is as close as you can get with the OP intention. But then you need some batch processing to change bit depth and/or sample rate.
No need, just select the desired format in the export window and PT should (and I say should because 32bit ip seems to be broken) convert everything on export.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 11-21-2019, 05:31 AM
Zarabozo's Avatar
Zarabozo Zarabozo is offline
First of all, you can only bounce outputs, not tracks. So if you wish to bounce your 20 tracks you need to have 20 outputs set for your tracks. If you haven't set it up like that in your mix, you need to bounce all tracks individually.
You can bounce busses too, not only outputs.
The audio world is full of (mainly very expensive) placebos.
Windows 10 Pro 64 Bit
Pro Tools Ultimate (perpetual with active updates/support plan)
RME Fireface 802, Focusrite Clarett+ Octopre, Eleven Rack (ERXP)
Monitors: Yamaha MSP7 and Yamaha HS8S
Asus RoG Maximus Hero Z790 (in a 4U slidable rack mount! )
Intel Core i9-13900k 5.4 Ghz (16 cores / 32 threads)
128 GB RAM G.Skill DDR5 6000 MHz (4 modules 32GB each)
Boot disk: Samsung 980 Pro M.2 2TB
Media disks: 2 x Samsung 980 Pro M.2 2TB in RAID 0 for current work, 2 x Seagate Exos X20 20TB mirrored for archive and backup
Video: PNY/Nvidia RTX 3080 TI with a single 4K display Dell U3223QE 32''
Old 11-21-2019, 05:36 AM
Zarabozo's Avatar
Originally Posted by teacherman View Post
I've got a session of 20 tracks.
I have a song that is 4:00 mins in length and that is comprised of 20 audio tracks.
Is it possible to bounce all 20 tracks to individual files all at the same time...this would take about 5 mins total.
Or, do I have do (20) separate bounces??....errrrrr... that would take about about an 90 mins to do that...
thanks,
You can do this to save time:
1) Create a send on each track, each to a new audio track. You can name all those new tracks with the prefix STEM so you can identify them easily later.
2) Record on all of those new tracks. This way you will have a bounce of each track including any plugin processing.
3) You can find the created files in your audio folder. If you need them in a different sample rate, then go to step 4.
4) Select the stem tracks. Go to the File menu and export selected tracks as new session. Set the desired sample rate and bit depth in your new session. Then go to the audio folder of that new session to find your files.
This may sound a little complex, but you can do all of this in less than 10 minutes.
HTH
Old 11-21-2019, 06:00 AM
Philthy Philthy is offline
thanks,
Consolidate, select the consolidated regions, Control + Shift + K. Select bit depth and sample rate as needed, save into a new folder. There you go.
If you need the effects printed you just Commit the tracks instead of consolidate, and select the committed regions.
You can access that same "export clips as files" from the drop-down menu at the top of the clips panel (the panel you expand on the right-hand side of the edit window.)
Phil Mann
Silk City Music Factory - CT Recording Studio
  #16
Old 11-21-2019, 06:05 AM
Originally Posted by Panacci View Post
Consolidate all the tracks and then go into your audio folder of the tune and you should see the time you consolidated. Take those tracks.
"Export clips as files" will do the conversion he asked for too.
Phil Mann
  #17
Old 11-21-2019, 06:06 AM
The export clips as files dialogue offers conversion of sample rate and bit depth.
Phil Mann
  #18
Old 11-21-2019, 06:07 AM
HTH
Commit -> Export clips as files. Should take about 1 minute, and achieve the same result.
Phil Mann
  #19
Old 11-21-2019, 06:08 AM
Originally Posted by Prabha View Post
This kind of feature is what PT has been missing and other daws do (like cubase)
It's not missing. You just have to know how to do it.
Phil Mann
  #20
Old 11-21-2019, 07:06 AM
That's what I was trying to say in post #3, easiest way I've found
amagrasmusic.com
Bouncing multi-channel audio altoidboy Pro Tools 11 14 04-22-2014 12:46 AM
Time remaining stuck while bouncing! It takes twice the time Retinal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-10-2008 08:33 AM
Bouncing tracks - taking a long time Gonkboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-26-2007 03:02 AM
Multi-channel vs Multi-mono plugs on 5.1 tracks geitz Post - Surround - Video 0 06-08-2007 09:06 AM
Multi-channel vs Multi-mono plugs on 5.1 tracks geitz Pro Tools TDM Systems (Mac) 0 06-07-2007 02:54 PM
