Tried Everything to Get Rid of Static/Popping? Try This.
Hi there!
So, I've posted pretty extensively on the Avid forums and M-Audio forums over the last two months about a static/popping noise occurring in Pro Tools SE through the M-Audio Mobile Pre interface. If you've tried all of the optimizations like did and nothing fixes the problem, don't go out and buy a super-strong sound card or a 1 terabyte external hard drive like I did (even though external hard drives are a MUST)... try this: Unplug your M-Audio USB that's attached to your computer, and plug it into an external USB hub (check if there is a USB port on your monitor - there was on mine). I did that, and after MONTHS of agony and frustration over this product it fixed the problem completely. No static while recording, mixing or playback EVER. Regardless of track numbers. Hope this helps. |
Re: Tried Everything to Get Rid of Static/Popping? Try This.
I wish my monitor had a usb port ive been having a really bad time with popping and static, it goes away if i Minimize Pro Tools SE but that helps none . ive tried just about everything I feel
So I got rid of my Popping/white noise a different way, I could not for the life of my for 2 days find the source of the problem so I decide to look at my USB cord, it was about 10 years old, so I decided to use the one that came with my Mk2. It said high speed on the cable where as my original one did not. It took a good amount of the popping out, It still pops every now and again but not nearly as much!
I was hoping a usb hub would solve my problems too, but it didn't i tried it as i have a nice powered usb hub, im on a laptop by the way, it made no difference on my system, i wish it did.
Thanks for the idea anyway. Tommy |
Aside from trying the external USB hub, are you recording to and on an external hard drive?
Absolutly, a firewire external drive.
Thanks though. Tommy |
In another thread on this forum "Distortion with Reason Rewire" Cherryfarmer suggests disabling the internal sound card ( on his/her laptop)...anyone tried that to see if it makes a difference?
Yes. That's one of the steps I did. I bought a better sound card (the on-board ones are terrible for music creation) then disabled the on-board sound card.
I have also experienced the static noise on ProTools SE, and after many hours of testing several things, I managed to get rid of this problem.
I changed the buffer size to 512, and since them I did not have static noise problems during recording or playback. The buffer size is by default 128, and the only way to change this is by going to File/Preferences/Audio and set it to Mixing or Producing, and it will automatically be set to 512. Otherwise the latency on M-audio Properties is always set to 128 - you should open the M-AudioPre Properties to see the latency. (See my thread "White noise / latency problems") This worked for me, but I have to bear the higher latency. I hope this will work for you. Let me know. |
popping/static during playback. Here is Sandra report. Please help! | Josh Franklin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 12-21-2011 04:47 PM |
Popping | shultzee13 | Pro Tools M-Powered (Win) | 8 | 06-24-2009 08:42 PM |
Popping!! | themachinesneverdie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-19-2006 09:27 AM |
Popping Ps | bigcow | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 05-24-2003 08:43 AM |
Static or Popping when I record vocals | ceo22 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-18-2003 05:12 PM |
