What makes Pro Tools HD so amazing?
Ok so I am learning about HD and DSP processing cards of that etc. I have heard the sound difference too. So my basic question is why does Pro Tools HD with those DSP cards sound much better than a Mac or PC running LE?
I am also asking a similar question to Access Virus - why the Virus TI unit - acting as the hardware processor for the RTAS virus control plug-in - why does it sound so much better and clearer than my computer running some soft synth (same sample rates, etc) in terms of fidelity... this is very wierd because I thought there is not supposed to be a difference in sound quality once in the digital realm. But one salesman told me hardware matters. Can anyone elaborate a little but? Because I am noticing a sound quality difference in hardware components even in the digital world. Very strange considering it's all 1's and 0's. |
Re: What makes Pro Tools HD so amazing?
Please do a search of this site.... this has been beaten to death. Do we really want to do it again? ff
Just summarize it for me in a nutshell. I tried a search already.
Yes and No. Absolutely! Definitely not! ADC! Subjective! Objective! An obvious difference! No noticeable difference!! Clear enough?
Unless your name is Kevin Flynn, you have to get out of the Digital World and listen in the real world like the rest of us - it's only 0's and 1's up to a point.
If you could listen from "inside" the digital world, and assuming you had been very attentive in how you had set up your HD & LE sessions, then they should null, making them identical. In the real world however, the HD signal will have travelled through a 48bit fixed point audio engine (Vs LE's 32bit floating point engine), it may be being passed through a dithered mixer - if that is the option you have chosen, and you may have ADC enabled (which if you havent made manual adjustments for in your LE session - assuming some of your plugins are inducing latency - could be clouding your mix). All that is before you hit the hardware digital to analogue converters, which is where you first get to "hear" the signal. Obviously the converters in the HD hardware are of a higher quality than those of the LE hardware - in a nutshell. |
LOL! |
Oh...that's easy...the World Class Customer Service!
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
HD doesn't sound better than LE. sh*t in, sh*t out.
HD... Great Taste!
LE... Less Filling! M
System#1 PT 10HD Harpertown Lion HD4 Accel Magma PE6R4-I Motu PCI-424e ProControl 32 Faders System#2 PT 11 and 10.3.6 2012 Westmere Mountain Lion HDX MC Mix - MC Control - MC transport - MC Mix with Command 8 |
Man..... it goes to eleven......
2017 27" iMac 3.8GHz i5, 1TB SSD Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB Musician: http://www.ivanlee.net/ Design Engineer: http://www.propowerinc.com/resume.html |
Pro Tools SE - Bug Makes Software Unusable | Starwind Amada | Pro Tools SE and Essential (Win) | 2 | 05-14-2013 07:00 PM |
Pro Tools 8 Looks Amazing | barismanco123 | General Discussion | 2 | 12-18-2008 11:53 AM |
Amazing Youtube video of FAST Pro Tools songwriting | benny99 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-08-2008 12:57 PM |
Pro Tools 6.7 makes computer restart | msb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-21-2005 10:51 AM |
Import Audio makes Pro Tools crash | Purdy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-27-2005 01:31 AM |
