Old 10-08-2007, 12:01 PM
Deiniboy Deiniboy is offline
Default 002 with eMac
I am running an eMac OSX 10.4. I have been running Digi 002 on a previous eMac fine. I have had to purchase a new eMac machine!
Anyway, after installing PT once again, I am now stuck. Every time I click the PT icon I am hit with the message 'Digidesign hardware is in use by another application -(1133)'
I'm not sure what to do!
Thank you for your help.
Old 10-08-2007, 04:17 PM
Default Re: 002 with eMac
Hi again,
Can anybody help me with this problem?
Old 10-09-2007, 11:15 AM
I need some help, can't get this thing to work at all?
Anybody familier with this problem?
Old 10-10-2007, 01:11 AM
Old 10-10-2007, 01:21 AM
DJerry DJerry is offline
I think, die Digi Coreaudiodriver ist running. If it is, look in your Dock, click on its icon and click on "Quit". The driver will tell you it is connected, but simplay click "Quit Anymway". After this, PT should launch...
Old 10-10-2007, 11:29 AM
Jerry thanks for the reply.
I'm quite sure what you mean. What does 'ist' mean?
Thanks Jerry
Old 10-11-2007, 12:58 AM
Still haven't solved this problem. Any help is appreciated.
Old 10-11-2007, 01:06 AM
Avid's Avatar
Avid Avid is offline
Administrator
What version of Pro Tools LE are you using? If you are on Mac OS X 10.4, and you are trying to use any version below Pro Tools LE 6.9.2, then it will not work, and will give that error message.
Click on the Compatibility link* at the top of the page, and scroll down to the link for "Pro Tools LE Version Compatibility Grid for Mac OS X".
*Same as the Compatibility Information page under Quick Links in the Support section.
Administrator
Old 10-13-2007, 11:17 AM
Thanks, I'll do that. I understand that you can download PT from Digi's site that is compatible with your OS, but I have lost my manual which contains the Authorization code needed for download.
LE 7.3.1 on eMac - possible? Ash06 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-15-2007 02:28 PM
emac carvell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-03-2004 04:22 AM
eMac okay? justrob Tips & Tricks 4 06-26-2004 06:08 AM
eMac and LE comacat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-30-2003 08:18 PM
emac? DDP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-24-2002 12:59 AM
