Old 02-04-2003, 09:01 AM
kid pro kid pro is offline
Default Shortcut for moving Edit Selection Start to End?
If I have a selection, and I then want to have a new selection that starts EXACTLY where the last one ended, is there a keyboard shortcut for that?
Right now, the only thing I can think of is to manually drag the start arrow in the timeline all the way to the right until it meets the end arrow(with Link Timeline and Edit Selection on).
Thanks!
-kid music
Old 02-04-2003, 11:24 AM
Default Re: Shortcut for moving Edit Selection Start to End?
Try this - If you have Auto Name separated region enabled.. it should be a quick fix.
Hit Command+E to make a region of the selection - use the right arrow to scroll to the right, place the cursor to the left of the right edge of the new region and tab (without tab to transient enabled) so you're at the end of the region. Now hit Command+Z to undo the region that you created.. your timeline cursor will remain at the end point.
If you have QuicKeys.. you can make this into a macro.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Any shortcut to audition selection in edit window? Tom M macOS 3 07-19-2013 10:45 PM
Edit selection and playhead start Alexander K Pro Tools 10 12 05-30-2013 09:03 AM
Locate Cursor To Start Of Region/Edit Selection Napping Windows 12 11-29-2011 12:57 PM
Link edit and time selection shortcut? Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-27-2009 01:19 PM
Shortcut for moving a selection mhmh Tips & Tricks 8 06-08-2007 11:32 PM
