Old 07-30-2010, 10:24 AM
SWSPHX SWSPHX is offline
Default "1" and "2" on keypad for moving the cursor
IT usually is that when you press 1 or 2 it moves the playback cursor forward or backwards a little... lately it isn't doing it, it jumps and skips and plays audio. Which setting controls this?
Thanks
Old 07-30-2010, 10:26 AM
FajitaTone FajitaTone is offline
Default Re: "1" and "2" on keypad for moving the cursor
it's the "-" and "+" keys that nudge
Ray Trujillo
Freelance Audio Engineer
Old 07-30-2010, 10:32 AM
Stig Eliassen's Avatar
Check the "Numeric keypad" preference. I always have it set to Transport where 1/2 is back/forward by one bar, or rew/ffd if held down.
If that doesn't solve it you can try to trash PT prefs.
Old 07-30-2010, 12:29 PM
No, the 1 and 2 keys have two little arrows on them (on the PT Keyboard)
+ and - are for nudging, I get that... but I am not talking about nudging... I am talking about moving the playback cursor bar. It used to pop back or forward with each tap of the key, now it slides and plays audio and locks up and gives me a spinning wheel sometimes...
But, thanks PT, trashing prefs did it... Annoying that this is a solution, lol... I checked the pref and it was set to where I always liked it, 1 bar as well...So weird. Anyone else have this bug? Should we add this to the plate of yumminess that is Pro Tools 8.0.x
Old 07-30-2010, 12:59 PM
BaileyBass BaileyBass is offline
Its not a bug.. It is your prefs getting corrupted. You seem to have alot of issues with your rig. Using that app to "refresh" your system might not be a bad idea. Most of us do it regularly, and have far fewer issues. Good Luck, sb
Old 07-30-2010, 04:51 PM
I do have a crap load of issues, ever since 8 came out its been one cluster f*$k after another.
I actually did a clean install last week and things are running a bit smoother, although, still some weirdness.
I delete prefs about once a week, it seems that as I go I get clicks and pops and all kind of noise in my mixes that go away when I delete prefs... I am just pointing that doing that is annoying.
The studio has been booked about 2 months straight so I went ahead and loaded our other rig back to 7.4 and it is so much better-- so I swapped out for the work load on 7.4 but in spare time just trying to tweak out 8.0.4 so we can be good to go.
Old 07-09-2022, 03:14 PM
cfalkosky cfalkosky is offline
this got me too. this fixed it for me.
Prefs -> Operation -> Audio During Fast Forward/Rewind (uncheck it)
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
Pro Tools 9 "Pausing" when I press "Play" with Focusrite Scarlett interface eanderso22304 macOS 3 11-23-2011 06:45 AM
PT9 Session Troubles - "Bus Error" in "Main Thread" & Could not complete the Open... tohmit macOS 5 03-23-2011 12:13 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... leon777 Pro Tools TDM Systems (Mac) 21 10-15-2002 12:00 AM
