Old 11-17-2006, 08:18 PM
Royalston Royalston is offline
Default \"Unable to launch midi server\" grrrrr
Hi
Im running an mbox 2 and an RME fireface 800 (not at the same time).
The RME has always worked fine, and my system's midi has worked without a hitch.
But since I recently started using the mbox 2, I find that audio-midi setup is "Unable to launch midi server"...so I have no midi. Someone said I should update my system to 10.4.8...so I did (with the combined updater) - same problem is occurring.
Please note: Ive recently reinstalled everything from the ground up to make a nice working system that PT "likes"....and now this (!) ...It's very frustrating.
Thanks
R.
G5 dual 2.3 ptle7.1cs7 (installing cs10 now)
Mbox 2
Fireface 800
Old 11-28-2006, 04:53 AM
Default Re: \"Unable to launch midi server\" grrrrr
bu-ump...problem still happening...help please
Old 11-28-2006, 05:17 PM
Digi Engineering Digi Engineering is offline
Hi R,
Can you list the contents of your /Library/Audio/MIDI Drivers folder?
Thanks,
digi-eng
Old 11-28-2006, 06:25 PM
Hi
Thanks for the reply
heres the list
DigidesignMbox2MIDI.plugin
DigiDioMidiDriver.plugin
EmagicUSBMIDIDriver.plugin
Fireface MIDI.plugin
M-Audio USB Support.plugin
Note: The midi server seems to die after a while of the computer being on, upon restart it functions normally (for a while)
R.
Old 11-29-2006, 12:27 PM
Try removing the "DigiDioMidiDriver.plugin" component. It's only required for the 002 so you don't need it for the Mbox2. If that doesn't fix your problem, try removing the "DigidesignMbox2MIDI.plugin" - this is a required component for the Mbox2 but it will give use some good data if it fixes your problem.
Thanks,
digi-eng
Old 11-29-2006, 01:06 PM
DigiTechSupt's Avatar
You could also try this (before removing those drivers):
Go to MacHD>Users>your account>Library>Preferences>By Host and trash 'com.apple.midi.a bunch of numbers and letters.plist'.
Go to MacHD>Users>your account>Library>Preferences and trash 'com.apple.audio.audiomidisetup.plist'.
Empty the trash and restart, then see if everything is working.
Avid Audio Tech Support
Support FAQ
LE 8 - Unable To Launch Midi Server alfieboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 06-02-2010 04:17 PM
Files transfered server-server relay still downloaded from remote server Phill Barrett Aspera DigiDelivery 1 03-19-2010 01:58 AM
Launch error log: MIDI server [328] donbenjy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-08-2010 11:28 AM
Error: "unable to launch midi server"???? Bambison Pro Tools TDM Systems (Mac) 2 08-21-2007 06:01 PM
ProTools 7.3 + Midi Server won't launch. Registered 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-19-2007 01:46 AM
