Pro Tools 10.3.9 CPU Overload
Hey everyone,
I'm having some issues now after upgrading to Komplete 9 Ultimate and Pro Tools 10.3.9. Previous to this, I haven't had any issues running any VSTs what so ever. Some sessions with multiple audio tracks will run fine however 1 instance of Komplete is enough to can the whole session. Here are the errors that come up... A CPU overload error occurred. If this happens often, try increasing the "H/W Buffer Size" in the Playback Engine Dialog, or removing some plug-ins. (-6101) You are running out of CPU power. Remove some Native plug-ins or increase the CPU Usage Limit in the Playback Engine dialog. (-9128) Here are the Macbook Pro Specs: Version OS X 10.8.4 2.4 GHz Intel Core i5 4GB 1067 MHz DDR3 What are my options? This is crazy that it overloads with just one instance of Komplete going. Previous to the update I could run multiple tracks with multiple Komplete plug ins going. Any help is appreciated. This is KILLING my workflow. Thanks, Erik |
Re: Pro Tools 10.3.9 CPU Overload
Also - no issues in Logic Pro X. Which I don't want to use.
What's the CPU meter showing? 4gb of ram is on the low side...
Do you have the use the most ram setup in the native prefs?
Daniel HDX - PT12.5.1 - HD I/O 16x8x8 Win10-Pro (v1709)- 6 Core i7-6850k - ASUS X99 Deluxe ii D-Command Main Unit - 'Ole Blue http://www.sknoteaudio.com/ plugins rock and are affordable. Last edited by YYR123; 07-17-2014 at 03:09 AM. Reason: t |
Pro Tools 10 CPU Overload | trebot000 | Windows | 30 | 02-28-2013 11:02 AM |
pro tools cpu overload? | MTaborda | macOS | 3 | 10-29-2012 10:05 PM |
Pro Tools 9.0.3 CPU Overload | chopin88 | macOS | 29 | 07-27-2011 02:28 PM |
Please help me with pro tools m audio 8 cpu overload!!!! | Oboist | Pro Tools M-Powered (Mac) | 40 | 01-21-2011 08:21 AM |
Pro Tools 8.0.3 on W7 x64 - CPU overload | azirkin | Pro Tools TDM Systems (Win) | 9 | 12-28-2009 06:14 AM |
