Old 11-05-2009, 04:11 PM
Extreme Mixing Extreme Mixing is offline
Default Mac Troubles
I have a Mac 2x2.66 GHz Dual Core Intel Xenon machine. It had been stable for quite some time, but Has been acting up since I upgraded to 10.5.8 and installed Pro Tools 8.0.1. I added Trillian to the mix a couple of days ago, and I just downloaded the newest update, and will try that later today. I notice that my permissions are always in need of repair now, after months of not needing to even check them. If I repair them, then check again, they all need to be repaired. Again. How can I fix this? It seems to be the same, or a very similar list every time.
Here's a list of what's in need of repair, it that helps anyone.
Steve
Reading permissions database.
Reading the permissions database can take several minutes.
Permissions differ on "System/Library/CoreServices/AirPort Base Station Agent.app/Contents/CodeResources", should be -rw-r--r-- , they are lrw-r--r-- .
Permissions differ on "Applications/Utilities/AirPort Utility.app/Contents/CodeResources", should be -rw-rw-r-- , they are lrw-rw-r-- .
Permissions differ on "Library/Application Support/ProApps/Internal Plug-Ins/BrowserKit/iLife.bkplugin/Contents/CodeResources", should be -rw-rw-r-- , they are lrw-rw-r-- .
Permissions differ on "System/Library/PrivateFrameworks/BrowserKit.framework/Versions/A/CodeResources", should be -rw-r--r-- , they are lrw-r--r-- .
ACL found but not expected on "System/Library/User Template/English.lproj/Sites".
Permissions differ on "System/Library/CoreServices/Front Row.app/Contents/CodeResources", should be -rw-r--r-- , they are lrw-r--r-- .
Permissions differ on "System/Library/CoreServices/Front Row.app/Contents/PlugIns/DVD.frappliance/Contents/CodeResources", should be -rw-r--r-- , they are lrw-r--r-- .
Permissions differ on "System/Library/CoreServices/Front Row.app/Contents/PlugIns/FRSettings.frappliance/Contents/CodeResources", should be -rw-r--r-- , they are lrw-r--r-- .
Permissions differ on "System/Library/CoreServices/Front Row.app/Contents/PlugIns/FRSources.frappliance/Contents/CodeResources", should be -rw-r--r-- , they are lrw-r--r-- .
Permissions differ on "System/Library/CoreServices/Front Row.app/Contents/PlugIns/Movies.frappliance/Contents/CodeResources", should be -rw-r--r-- , they are lrw-r--r-- .
Permissions differ on "System/Library/CoreServices/Front Row.app/Contents/PlugIns/Music.frappliance/Contents/CodeResources", should be -rw-r--r-- , they are lrw-r--r-- .
Permissions differ on "System/Library/CoreServices/Front Row.app/Contents/PlugIns/Photos.frappliance/Contents/CodeResources", should be -rw-r--r-- , they are lrw-r--r-- .
Permissions differ on "System/Library/CoreServices/Front Row.app/Contents/PlugIns/Podcasts.frappliance/Contents/CodeResources", should be -rw-r--r-- , they are lrw-r--r-- .
Permissions differ on "System/Library/CoreServices/Front Row.app/Contents/PlugIns/TV.frappliance/Contents/CodeResources", should be -rw-r--r-- , they are lrw-r--r-- .
Permissions differ on "System/Library/PrivateFrameworks/BackRow.framework/Versions/A/CodeResources", should be -rw-r--r-- , they are lrw-r--r-- .
Permissions differ on "System/Library/PrivateFrameworks/ProKit.framework/Versions/A/Resources/LeopardPanels.bundle/Contents/CodeResources", should be -rw-r--r-- , they are lrw-r--r-- .
Permissions differ on "System/Library/CoreServices/Menu Extras/RemoteDesktop.menu/Contents/CodeResources", should be -rw-r--r-- , they are lrw-r--r-- .
Permissions differ on "Library/QuickLook/iWork.qlgenerator/Contents/CodeResources", should be -rw-rw-r-- , they are lrw-rw-r-- .
ACL found but not expected on "System/Library/User Template/English.lproj/Desktop".
ACL found but not expected on "System/Library/User Template/English.lproj/Library/Application Support".
ACL found but not expected on "System/Library/User Template/English.lproj/Library/Assistants".
ACL found but not expected on "System/Library/User Template/English.lproj/Library/Audio/MIDI Drivers".
ACL found but not expected on "System/Library/User Template/English.lproj/Library/Audio/Plug-Ins/Components".
ACL found but not expected on "System/Library/User Template/English.lproj/Library/Audio/Plug-Ins/Digidesign".
ACL found but not expected on "System/Library/User Template/English.lproj/Library/Audio/Plug-Ins/VST".
ACL found but not expected on "System/Library/User Template/English.lproj/Library/Audio/Plug-Ins".
ACL found but not expected on "System/Library/User Template/English.lproj/Library/Audio/Sounds/Alerts".
ACL found but not expected on "System/Library/User Template/English.lproj/Library/Audio/Sounds/Banks".
ACL found but not expected on "System/Library/User Template/English.lproj/Library/Audio/Sounds".
ACL found but not expected on "System/Library/User Template/English.lproj/Library/Audio".
ACL found but not expected on "System/Library/User Template/English.lproj/Library/ColorPickers".
ACL found but not expected on "System/Library/User Template/English.lproj/Library/Compositions".
ACL found but not expected on "System/Library/User Template/English.lproj/Library/Favorites".
ACL found but not expected on "System/Library/User Template/English.lproj/Library/FontCollections".
ACL found but not expected on "System/Library/User Template/English.lproj/Library/Fonts".
ACL found but not expected on "System/Library/User Template/English.lproj/Library/iMovie/Plug-ins".
ACL found but not expected on "System/Library/User Template/English.lproj/Library/iMovie/Sound Effects".
ACL found but not expected on "System/Library/User Template/English.lproj/Library/iMovie".
ACL found but not expected on "System/Library/User Template/English.lproj/Library/Input Methods".
ACL found but not expected on "System/Library/User Template/English.lproj/Library/Internet Plug-Ins".
ACL found but not expected on "System/Library/User Template/English.lproj/Library/Keyboard Layouts".
ACL found but not expected on "System/Library/User Template/English.lproj/Library/Preferences".
ACL found but not expected on "System/Library/User Template/English.lproj/Library/Printers".
ACL found but not expected on "System/Library/User Template/English.lproj/Library/Screen Savers".
ACL found but not expected on "System/Library/User Template/English.lproj/Library/Sounds".
ACL found but not expected on "System/Library/User Template/English.lproj/Library/Voices".
ACL found but not expected on "System/Library/User Template/English.lproj/Library".
ACL found but not expected on "System/Library/User Template/English.lproj/Movies".
ACL found but not expected on "System/Library/User Template/English.lproj/Music".
ACL found but not expected on "System/Library/User Template/English.lproj/Pictures".
ACL found but not expected on "System/Library/User Template/English.lproj/Public".
Permissions differ on "Applications/iTunes.app/Contents/CodeResources", should be -rw-rw-r-- , they are lrw-rw-r-- .
Permissions differ on "Applications/iTunes.app/Contents/Frameworks/InternetUtilities.bundle/Contents/CodeResources", should be -rw-rw-r-- , they are lrw-rw-r-- .
Permissions differ on "Applications/iTunes.app/Contents/Resources/iTunesHelper.app/Contents/CodeResources", should be -rw-rw-r-- , they are lrw-rw-r-- .
Permissions differ on "System/Library/Components/AudioCodecs.component/Contents/CodeResources", should be -rw-r--r-- , they are lrw-r--r-- .
Permissions repair complete
Steve Shepherd
Extreme Mixing
Old 11-05-2009, 04:24 PM
Default Re: Mac Troubles
just Repaired permissions again, then re-checked them, and it generates exactly the same list. Maybe it's not related to my Mac "buggyness" but it sure seems like it is...
Thanks.
Steve Shepherd
Extreme Mixing
Old 11-05-2009, 07:25 PM
Crank1000 Crank1000 is offline
That's why I clone my system drive once every couple weeks. If I ever get into a funky state, I can just clone back.
As for your problems, have you tried Disk Warrior?
Old 11-06-2009, 12:07 AM
I don't want to clone back. I want to keep my new instruments and use them. I really think it's the new STEAM engine. Every thing was looking so good, and then, Poof...
Steve Shepherd
Extreme Mixing
Old 11-06-2009, 12:43 AM
sleadley sleadley is offline
We had this problem and the only way to solve it was to re-install the system. The ACL problem seems to be the clue to this problem and we couldn't find a solution. Strangely, the Cloned Backup was also screwed, but after a system re-install all was OK.
Sorry , I cannot be of more help
S.
Plan for the worst, Hope for the Best.
www.trackdown.com.au
mtp av troubles gamblor Pro Tools TDM Systems (Mac) 1 01-25-2010 05:44 PM
002 with le7.4 troubles kalos 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-05-2009 04:11 AM
7.0 C/8 troubles macr0w ProControl, Control|24, Command|8 8 11-30-2005 04:49 AM
OT - PA troubles GothicV 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-25-2005 12:36 AM
Serious troubles with 002 R ISedlacek 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-17-2004 11:53 PM
