Old 03-04-2008, 06:59 PM
MixerGuy MixerGuy is offline
Default my pans in ProTools HD7.4 are linked - how do I unlink them?
my pans in ProTools HD 7.4 are linked - how do I unlink them?
OK I don’t recall seeing this ever before….. it must be a preference that I cannot find
in stereo audio tracks, i’m used to the left and right pan sliders being independent.
somehow they are now linked - and if I pan in the left, the right follows in, as a reverse mirror image. I dont want this. How do I turn this off? I looked in the manual, with no dice.
I tried assigning to different outputs (a buss, a hardware output, stereo SP/dif, etc - no luck. I tried rebooting - no luck.
aaaaaaaahhhhhhhhh :-(
thanks!
Old 03-04-2008, 07:44 PM
Bryan Cook Bryan Cook is offline
Default Re: my pans in ProTools HD7.4 are linked - how do I unlink t
i've seen groups link pans, but i haven't seen ungrouped tracks have linked pans. is there a group on? are there any automation dots when you select the pan view for that track?
if you want to turn off pan linking for a specific group, hit ctrl-apple-g to modify groups, then select the group you want to change and click the attribute tab and unselect the pan. if you want to unlink pans en mass to different groups, i would do the same as above (modify groups) and go to the "globals" tab and set up the way you most often like your groups to behave, then go to the group and check "follow globals"
hope that helps!
Old 03-04-2008, 07:51 PM
jimlongo's Avatar
jimlongo jimlongo is offline
There's a link button for 5.1 panners. If you open up the independent fader by clicking on the little widget in the I/O column in the Edit window it brings up a fader with panning (sorry I don't know what you call it, and I'm at home so I can't send you a screenshot).
Perhaps the same thing exists for stereo faders in 7.4 . . . I've never seen that before. Just a guess.
noise | jimlongo
Old 03-04-2008, 07:58 PM
In the Mixer Window, click on the Output Window Button which looks like a little fader... there you'll find a Link button.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 03-04-2008, 10:12 PM
no - this is a single, ungrouped stereo audio track.
I've just been told that the links that Rail mentions now default to ON in PT 7.4 - AAAAAAAAHHHHHHHHHHH
Digi - can we please have a preference for this? It is a hassle to unlink them all the time
thanks
Old 03-04-2008, 11:43 PM
25ghosts 25ghosts is offline
I'm on 7.4.1 and my stereo tracks do not default to linked stereo
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10
Old 03-04-2008, 11:50 PM
They don't defailt to linked here either.
Rail
Platinum Samples
Old 03-05-2008, 02:12 AM
Andre Knecht Andre Knecht is offline
It sounds like that particular stereo was routed to a multi-channel path because, according to the documentation…
Multichannel Panner Linking
Stereo tracks with multichannel outputs provide
left and right multichannel panners. The Output
window provides controls to link the left and
right channels for precise panning.
When you create a stereo track that is routed to
a multichannel output, the following pan link- age
controls are active by default:
• Link (links Left and Right pan controls)
• Front Inverse (inverts Left and Right pan
control linkage across front)
• Rear Inverse (inverts Left and Right pan
control linkage across rear)
The Front/Rear Inverse pan control is unlinked
by default.
(PT 7.4 Reference Guide, Chapter 41: Surround Panning and Mixing (Pro Tools HD Only), Pg. 872)
The same information also appears in the “What’s New In HD 7.4” document (Chapter 3: Miscellaneous Pro Tools Features and Enhancements; pg. 49).
IHTH.
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 03-10-2008, 11:54 AM
by default.
IHTH.
aha - cool - thanks!
I suspected this to be the case..... right at the beginning....
initially when i thought this was the issue, I assigned the output of the track to a stereo path - but the link stayed - i guess it doesn't 'unlink' once it is linked.....
interesting....
thanks!!!
link aux pans to main pans JZStephan Pro Tools TDM Systems (Mac) 2 11-24-2008 07:46 PM
LINKED aaf and MXF media Protools 7.4.xx pkingduk Post - Surround - Video 1 09-05-2008 05:37 PM
Files linked, not linked, linked, not linked.... Rader Ranch Pro Tools TDM Systems (Mac) 3 08-20-2008 08:18 AM
Send pans follow channel pans? woodshopsound Pro Tools TDM Systems (Mac) 2 10-14-2004 02:36 PM
Protools linked to Reason???!!!! yuppie Tips & Tricks 5 11-05-2001 08:57 AM
