Recording Latency, (Have to shift regions after recording)
Every time I record audio I have to nudge the region back in time to get it how it should sound. This affects my work flow greatly.
I had a session with a rapper yesterday and I wanted to record each line separately. This meant I had to record a line, then zoom in and nudge it back in time, play it a couple of time to make sure it was right then move on to the next line. This really affected his flow and the end result was unnatural. Also, the region will never be at the exact same time in which it was recorded. This annoys me greatly. pleaseeeeeeeeeeeeee help me. cheers Bruce |
Re: Recording Latency, (Have to shift regions after recording)
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
this is with no plugins on the track. if the session is completely empty its not so bad. as soon as the session gets even the slight bit complex it lags real bad. Tried all levels of buffer and it doesn't solve the problem.
Pro Tools LE 8.04, Windows XP SP3. MBOX 2 USB. Quad Core Q9550 @ 2.83 GHz 4GB Ram, ATI HD 4850 1GB Graphics. cheers |
aha i think i have worked it out. I was using Izotope Ozone on my master channel to avoid clipping, and when i take it off the problem goes away. is there any 'low cpu usage' plugins i can use on my master to stop it clipping during mixing?
thanks |
Leave Ozone out until after all your tracking is done(actaully, leave out ANY plugins on the master track until its bounce time). If the master is clipping, just pull it down and turn up your speakers/headphones. Or hit the ALL group and pull ALL you tracks faders down 3-4db. The clipping should not hurt anything during playback, and you can add in Ozone when you get ready to bounce. You can leave Ozone inserted and make it inactive until the bounce(inactive, not bypass).
Any clipping that happens post fader does not matter while tracking. As long as your actual audio isn't clipping coming in (pre-fader), then you don't need to worry about anything that is clipping until you mix the record.
www.HellfireBeats.com UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61 Pro Tools 2021.12 Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2 16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1 27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15 |
Crackling during playback and key shift up after recording | Featherstone | macOS | 5 | 08-17-2012 07:10 PM |
low latency recording vs low hardware buffer size recording | chrisdee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 01-27-2009 06:49 AM |
Recording Latency - shift back 95 samples? | angelataylor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-23-2005 10:11 AM |
164 Samples Shift for Recording Tracks on the Mac | bhaktamatt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-26-2004 04:00 AM |
Whats the difference between Low Latency recording and recording on low latency with | Dead River Studio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-25-2002 01:22 PM |
