Old 07-19-2002, 04:55 PM
Siegfried Meier Siegfried Meier is offline
Default Using 888\'s as standalone D/A
We would like to use AES in 3/4 of one of our 888's to play back a stereo stream of another editing system. How is this possible without running an Aux in of PT? PT obviously can't be running, correct? Thanks.
Best regards,
Siegfried Meier
Old 07-20-2002, 09:29 AM
Default Re: Using 888\'s as standalone D/A
Bump
Old 07-20-2002, 05:30 PM
5down1up 5down1up is offline
[img]images/icons/confused.gif[/img]
thats how i get it , output of your aes device , connected to the aes - ins of the 888/24 ,create 2 channels , select input 3-4 digital in the setup menue , press record on those tracks and thats it.
dont get what you mean with an aux - input ???
or even about the topic itself " as standalone d/a " .
if PT is your frontend your suggestion would work like that - digital device outs - standalone 888 ins - standalone 888 outs - Protools connected Interface ins - that doesnt make sense at all ???
maybe its too late and i am not gettin it ???
[img]images/icons/grin.gif[/img] good luck
Old 07-21-2002, 10:33 AM
I'm using a different editing program and I'm trying to use 2 digital inputs of an 888/24 as my input so that I may monitor through a pair of D/A converters on that 888. With me? I don't want to use ProTools at this point. I believe the converters can only function if the Mac is actually not turned on at all. The only way I can make this work is to create an AUX in(same as making a new track and record enabling), set that for input 3/4, and make inputs 3/4 digital in the Digi control panel. Still with me?
Best regards,
Siegfried Meier
888's Woodya Pro Tools TDM Systems (Mac) 1 10-09-2004 05:36 PM
001 vs 888's Joz Tips & Tricks 13 08-18-2002 01:56 AM
two 888's to three 888's ... what do I need? qr2r General Discussion 2 12-09-2001 07:18 PM
3 cards, 2 888's, and a G4/667 Eric Amdahl Pro Tools TDM Systems (Mac) 5 10-16-2001 06:11 AM
How often do you calibrate your 888's? Anibal Tips & Tricks 0 02-08-2000 08:33 AM
