Old 11-21-2020, 12:08 PM
rdpar's Avatar
rdpar rdpar is offline
Default Bounced track shows nothing
When I bounce a track and import after bounce, it shows no wave form at all and plays nothing. even in the folder I bounce to , same thing. ?????
Windows 10 Pro Tools 2019 Asus g752vt 17.3" laptop i7 Quad 2.6ghz 32gig ram
256ssd 1t hdd win. 10 Universal Audio x8P , Audient id22 interface. Focusrite Clarett Octopre
Old 11-21-2020, 05:27 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Bounced track shows nothing
What is the Bounce source?
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 11-21-2020, 07:36 PM
rdpar's Avatar
It's a track of my song that I just printed and am going to master. I duplicated the track and bounced the duplicate and it worked fine.🤔
Old 11-22-2020, 10:02 AM
Not sure if this applies to you, but I have had(once or twice) a routing issue where a session ended up having 2 paths with the same name. 1 path was the normal Main Out L/R path(my normal main output) and the other was a bus with the exact same name. When playing the session, I could hear everything, but when I did a bounce, the tracks that had their output as this bus would not be heard in the bounced file. Finding it was as much of an accident as whatever caused it
And, while it has not happened in a long time, I did have a few sessions that defaulted to a bus as the bounce source(something that's easy to miss if you are in a hurry). Once the source was set correctly, each session bounced properly. Trashing prefs is always worth a try for any "odd" behavior
Bounced track becomes too low in volume! firmflange Pro Tools 12 16 02-25-2016 02:08 PM
bounced to QT track order vudoo Post - Surround - Video 0 11-28-2013 12:00 AM
Bounces selected track but shows remaining time of longest track mwsmith007 Tips & Tricks 5 01-06-2013 08:21 AM
looking to loop bounced track gregfl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-29-2008 08:07 AM
Silence before bounced track kiwiben 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-10-2003 02:53 PM
