Old 01-20-2003, 07:56 AM
Centurion Centurion is offline
Default Automation point resolution
When moving automation points via the mouse (up/down) the resolution jumps around in large increments, such as say volume adjust from 1.0 to 1.3 and such. Is there a way to nail the automation points in the edit window to discrete values by entering them in some field somehow?
Old 01-20-2003, 08:58 AM
Daniel_Dettwiler Daniel_Dettwiler is offline
Default Re: Automation point resolution
Yep, it is more precise when the hight of the track is bigger. Or just press "command" while you moove the points, that will also save the problem and let you make mimor changes. There is no way to have the value entered in text form though...at least not that I was aware of
Hope this helps
daniel
Daniel Dettwiler
Idee & Klang
www.ideeundklang.com
Automation curve resolution jschmidtiii macOS 2 04-07-2013 07:31 AM
Resolution when adjusting automation points with trim tool mahler007 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 06-09-2010 06:44 AM
Automation Resolution blizzard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-02-2010 02:15 PM
Automation points resolution ishur Pro Tools TDM Systems (Mac) 3 09-17-2006 02:30 PM
Automation point moving Sparks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-22-2002 03:46 PM
