Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 01-05-2021, 06:28 AM
Talisker Talisker is offline
Default Why is PT 2020 not located under "applications " ?
Is there a reason, why PT 2020 insists on living in the documents folder rather than in the applications folder ? I moved it over manually and since then I had two versions of the program because it immediately located another copy under documents. Why is that ?
Mac Mini M1, 16 GB Ram, OSX 10.181.1,Focusrite Scarlett 18i20,Behringer ADA 8200,Pro Tools 2022 2xGlyph hard drive 750GB
Old 01-05-2021, 08:03 AM
Default Re: Why is PT 2020 not located under "applications " ?
There is a "Pro Tools" folder that's created on install and lives in the documents folder - it contains all the user-specific resources (plug in settings/maps, I/O settings, documentation, etc, etc), but the actual Pro Tools app lives in Applications as it's supposed to - if it doesn't on your system then something is wrong with the install.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 01-05-2021, 08:13 AM
^^^ yep you have likely just gotten yourself confused. You need to be looking carefully for the location of “Pro Tools.app” not just any folder called “Pro Tools”.
Start by setting the Finder to show file type extensions. Google how to if not sure.
If in doubt in Terminal:
$ find / -name “Pro Tools.app” -type d -print
Will find all likely “Pro Tools.app” apps.
Old 01-07-2021, 05:08 AM
All good .I failed to find the app because I was looking for it in the avid folder under applications....that's where it used to be. I didn't look for the stand alone pro tools app in applications. But now I found it.
Yellow "move" box for plugin is off 2020.11 kilroyrock Pro Tools 2020 3 12-10-2020 11:10 AM
Best current "Advanced Tutorial" for PT 2020 DBK Pro Tools 2020 0 07-28-2020 08:58 PM
"Digidesign Midi I/О" in "ProTools 10HD" in "OSX Maverics" electra1006 MIDI 0 06-18-2018 05:46 AM
Need help!!"unable to located digidesign hardware" ttylaa Pro Tools TDM Systems (Mac) 9 12-20-2010 08:53 AM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
