Old 12-26-2008, 11:18 PM
Mergerboy Mergerboy is offline
Question Upgrade from Amp Farm to POD Farm Platinum
So the nice people at Line 6 have offered the opportunity to upgrade to POD Farm Platinum for $99 to licensed users of Amp Farm 3.0. Great news, and the POD Farm product has the best graphical interface for Pro Tools you've seen. The license for Platinum downloads nicely into iLok. So far so good.
Now: how on earth do you find the Platinum software to download? Off the Line 6 site it's relatively easy to download the regular POD Farm software, and it works fine in PT8.0. But how do you get at the Platinum (with all of the additional components)?
Mergerboy
PT8.0; G5; 192; Leopard
Old 12-28-2008, 06:32 PM
Snitz Snitz is offline
Default Re: Upgrade from Amp Farm to POD Farm Platinum
There's only one installer, POD Farm. Your platinum license will unlock all amps and efx (the regular license shows some stuff grayed-out). For $99, it's a ridiculously good deal, tons of stuff inside, and the plugin allows you to chain amps and efx together in whatever manner you like. Big mistake not to take this upgrade, and no, I don't work for Line6.....
Old 12-28-2008, 06:42 PM
studiojimi's Avatar
studiojimi studiojimi is offline
what if you want to work in 7.4.1 still as you are getting used to 8.0
and need amp farm there and not the upgrade
will that work?
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
Old 12-28-2008, 06:48 PM
A1's Avatar
A1 A1 is offline
One question... over the years we have done many projects using AmpFarm.
So, if I were to recall a session from say a couple of years ago will PODFarm be compatible and give me the same settings?
It is not very clear as to if this is a totally new plugin or an enhanced version of the old one with backward compatibility...
Old 12-28-2008, 06:56 PM
alw4416 alw4416 is offline
its more or less like owning a pod x3
Old 12-28-2008, 08:04 PM
WernerF WernerF is offline
You can still use Amp Farm if you do the upgrade to PODFarm. They are totally different plugins. The sounds are different and, by the way, much better in PODFarm. As alw4461 said, it's all of the sounds in and functionality of the Pod X3.
Old 12-28-2008, 08:21 PM
Siegfried Meier Siegfried Meier is offline
Where are you guys finding the upgrade? I can only see regular purchases through the store...
Thanks!
Sig
Old 12-28-2008, 09:50 PM
jfredk jfredk is offline
A1:
I would think Amp Farm will still be available in the TDM drop down menu and Pod Farm would be in the RTAS menu.
I cannot believe they would make it inoperable with an RTAS update for a TDM plug.
If that's the case I'll hang back with the TDM version, thank you very much.
And though this was a Digidesign sent message I find no mention of it in the "News" drop down on the Digi boot page. And there is no clarification on the Line 6 pages or FAQs either--to my eye anywaze.
Anyone out there know where the actual skinny is regarding this?
Digi?
J Fred in Nashville
G4 MDD Dual 1.42, 2 gig RAM, MAC OS 10.4.11, PT 7.3.1cs8, 192 I/O, Gibson Stereo 79RT
Old 12-29-2008, 12:11 AM
Howardk Howardk is offline
From what I see it is not a special deal and I'd say the End-Of-Life email was misleading. . . that is low down! After buying Amp Farm and paying all the upgrades along the way, it appears we have no advantage in this deal because it appears to be $99 for anyone off the street from what the website says. See below:
POD Farm
( iLok License )
POD® tone in any DAW $99.00
Item cannot be returned. Return policy
This is an iLok License. You must have an iLok device to use this product.
POD Farm is the new plug-in software platform that enables POD tone in virtually any DAW and is Mac® AU/RTAS/VST and Windows® RTAS/VST compatible for seamless integration with all major recording software applications.
It's an upgrade for owners of iLok® hardware that gives you ultimate flexibility with a crucial collection of tones no recording guitarist should be without. For example, after you record a dry guitar signal you can audition different tones for it during playback without changing your original recording. This way you will always have the right guitar tone to fit the song without having to re-record that "perfect" riff. You can also stack multiple amp and effects models to further customize your guitar tone. You can even split your guitar signal and play through two full rigs of amps, cabs, effects and more to produce classic dual tone combinations or gorgeous new hybrids. Dual Tone presets provide tried-and-true tone combinations in an instant.
Old 12-29-2008, 12:34 AM
Camilo Orozco's Avatar
Camilo Orozco Camilo Orozco is offline
Thanks!
Sig
I want to know as well. Can someone post the link to the UPGRADE?
Camilo Orozco
Like us on www.facebook.com/artedigitalestudio
www.estudiodegrabacion.com.mx
WTB: Line 6 Pod Farm Platinum 2 iLok asset ejwells Buy & Sell 6 03-23-2013 09:35 AM
Much difference between Amp Farm and Pod Farm Platinum Raoul23 Eleven Rack 3 05-07-2011 09:34 AM
POD Farm Platinum/iLok/ PT8 Snafu...HELP PLEASE! Broman2999 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 03-22-2010 06:14 AM
POD Farm/ Platinum users help! TreeDaddy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-28-2009 12:28 AM
