Help....pci bus full.....need to move tracks
Hi, I goofed and recorded all my tracks so far to my 2nd internal drive when I meant to record to my two fire wire drives. How can I remove the tracks from my internal drive and divide them amongst my two fw drives? Please only advise me if you know for sure how to fix this. I don't want to create another nightmare.
thank you, STeve |
Re: Help....pci bus full.....need to move tracks
Hi!
While testing the possibility of actually getting all 192 voices going with Accel, I did something similar. First, back-up your session- always. Next, if you used good naming habits, *knowing* which audio files are which regions for which tracks, etc should be easy. Keep the regions for certain tracks or groups of tracks together. Then simply create folders on each firewire, call them the same as you call the session folder you are currently using.create an Audio file within each. Move the groups of *like* files as you want. Open session, and use linking to find all the files. If you have Digibase set up well, autolink should work fine. Save session with a new name, so you know it is the redistributed file session. Walla! Should be good to go. I have not used firewire drives yet (no reason to for me), so if there is some caveat I am unaware of here, please correct me. In my case, the 192 would play from a single drive (yeah, big suprise- lol). I saved the session, close dit, moved the regions for 52 of the tracks to a different IDE drive, reopened session, linked files, and all was well and good in the land of ridiculous track count.
nikki k Eagles may soar, but weasels don't get sucked into jet engines. On the other hand, you have different fingers. |
Nikki, a few things that totally went over my head. I think I understand the basics of what you're saying, but two things:
-Digibase? never heard of it and I can't find a mention of it in the manual -linking? how do I set this up...don't see it in the manual either thanks very much for your time. ps...I'm on xp.........you're not on mac are you? |
Move the red diamond in the tempo bar in the edit window, only some tracks move | kingheartless | macOS | 2 | 02-21-2013 03:20 PM |
Move region between tracks | cananball | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-06-2010 10:56 AM |
Playlist tracks don't move with other tracks | sean shannon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 10-22-2006 01:02 PM |
How can I move tracks in the mix window? | Herkimer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 10-30-2005 02:37 PM |
Need Help - Faders for Tracks Move Together? | JCWarrior | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-05-2005 06:44 PM |
