Old 03-04-2019, 07:47 AM
subhuffer subhuffer is offline
Default Produce at 96 kHz for a higher quality 48 k output?
Hello,
I am working on creating tracks for sync purposes (video, and streaming) and I am also would like to work on film composition in the near future (also working in Dolby Atmos)
My question is working at 96khz something done widely in the industry or should I just stick with working with 32 floating point and 48khz
I have Pro Tools Ultimate running on an RME baby face pro. I have Adam a7x with Mogami cables in a decent enough treated space. I also own a pair of HD800s.
I ask her in post since I am wondering what resolution are you all working in and what type of files do you receive stuff in
thanks
Old 03-04-2019, 08:58 AM
BScout BScout is offline
Default Re: Produce at 96 kHz for a higher quality 48 k output?
Post is still standardised on 24bit fixed, 48kHz.
If you want to work at higher or 32 bit floating, you will be asked to convert before delivery to 24 bit fixed, 48khz. Which isn't a big deal but will be asked.
Old 03-04-2019, 09:02 AM
K thanks for your response. In that case I will just work on 24bit then. When it comes to interfaces, I don't really record and I work mostly with sample libraries so the RME is working great for me.
Outside of HDX TDM interfaces (which I am not interested in), would I benefit at all from getting an HD Native or HD Omni interface?
Cheers
Old 03-04-2019, 10:08 AM
KingTor KingTor is offline
A post supervisor once told me the soundtrack is supposed to be delivered at 96k 24bit, but I have never seen that on a spec sheet.
sent from a stupid phone using Tapatalk
Tor Kingdon, Chief Sound Guy
Hear Kitty Studiostwitterfacebook
Old 03-04-2019, 10:14 AM
yeah I just emailed a guy who does the mixes for Pele movies and sound Star Wars stuff and he said just to work on 24/48, all the top pros do
Old 03-06-2019, 02:26 AM
If you manipulate your audio like a sound designer and change its pitch or and up stretching it, 96k can be beneficial. It contains more data for the algorithms to work with, which I feel, ends up affecting the quality of the output.
If you don’t manipulate your tracks then the only real advantage is pushing that Nyquist low pass well above the range of our hearing, so it won’t affect the high end. The jury is still out on whether this is a big deal or not, however.
Old 03-06-2019, 11:57 AM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
Only times I was asked to record 96k were for character recordings for monsters etc.
Vedat
WaveRider + Defaulter (now with LKFS)
QuietArt.co.nz
Catchin' SYNC app
Old 03-06-2019, 08:06 PM
sounds like a nice project, but generally, outside of special requests, you work in 24/48?
Old 03-06-2019, 11:06 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
I can also state that everything we do at WB is 24/48 unless we're recording creature voices, then we'll do 96k and very rarely 192k. For my independent post-house, it's 100% 24/48.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 03-07-2019, 08:08 PM
Thank you for your input, I was working on 24/44 but now that I am writing/composing for sync music, wanted to double check that everything was still on 24/48 for the most part
cheers
HTML code is On
the best quality video output for PT capt kirk Post - Surround - Video 12 04-14-2012 06:11 AM
Using 18 channels of not m-audio I/Os (even higher quality)? UlrichKe Pro Tools M-Powered (Mac) 0 03-13-2010 05:20 AM
96k and higher digital output on 192 interfaces? InjuredEar Tips & Tricks 3 01-13-2006 08:27 AM
Sound quality difference with higher sample rates jwd65 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 09-16-2004 01:05 PM
Will a Higher Quality Power Cord improve the Sound? leon777 Pro Tools TDM Systems (Mac) 6 10-01-2002 09:29 AM
