System 5 Brightness Utility
We installed a new 408 module. The TFT brightness is set to 160, whereas all other modules have 120. How do I use the brightness utility to get 120 on all modules? What are the necessary settings in the configuration file? thanks! Philippe |
Re: System 5 Brightness Utility
Typically the brightness utility needs to be run from a command prompt, and requires that you enter the desired numeric value at the end. Example: >bright 120. Another way to change the brightness on a single module involves FTP'ing into the module to get the config file, edit it with the correct setting, and put it back. Instructions on how to do that can be found here: http://avid.custkb.com/avid/app/self...n&DocType=1080 Keep in mind that even with the same numeric value set for brightness, displays of differing age may not look exactly the same. |
Dear H.G.
Thanks a lot! This worked well. The new modules seem to have much more brightness though. I needed to set the brightness of the new module to "60" in order to obtain the same brightness as old modules on "120". Now I just need to update all the other modules to get these smooth and silent new faders! :) Philippe |
Sync IO LCD Screen Brightness | Siegfried Meier | Pro Tools TDM Systems (Mac) | 3 | 04-10-2013 11:56 AM |
System drive back up with disk utility question | crizdee | Pro Tools TDM Systems (Mac) | 2 | 06-19-2005 01:58 AM |
NULL Command Under System Configuration Utility | The Weed | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-08-2004 02:16 PM |
Protools LE & XDV on same XP system utility test | michaelmovies | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-10-2003 12:01 AM |
Adjusting brightness of meters on 888? | JaredV | Pro Tools TDM Systems (Mac) | 3 | 03-21-2000 09:10 PM |
