The document could not be opened because it was created with a newer version .....
OMG after I finished a MIX Protools froze while closing now im getting this :
The document could not be opened because it was created with a newer version of pro tools There is a fix for this or I lost the mix ?? I know I can import the files to a new session but I don't want to lose the MIX !!!
Mac M1 Studio Ultra - Sonoma Beta OS Avid Carbon Interface Protools Ultimate |
Re: The document could not be opened because it was created with a newer version ....
Try opening some of the auto-backup versions(look for the latest time/date and work backwards).
Thanks albee the problem with that is that it was turned off i dont know why !!
just out of curiosity what is the session files extension? is it XXXX.ptf or xxxx.ptx???? If it is .ptf try changing it to .ptx
Worth a try but sounds like you lost it when it crashed... like didnt finish writing the session file before it went down.
-Systems Engineer, Systems and Sound Designer, Recording and Mixing Engineer |
Hi its .ptx im gonna try the inverse ....
Nothing same result !
you have a corrupted session file. if no session file backups exist then you are rebuilding from scratch.
C |
Yeah i know .....
It's 2018 and I'm getting this same error (newer version) trying to open a .ptf file that hasn't been opened since 2011.
Pearlman Church Microphone > Great River MP-2NV > Warm Audio WA-76 > Apogee Symphony MK II 8x8+8MP > PT2018 on 2018 Mac Mini with 32GB of RAM running Mojave. |
other ideas: First thing to try is to create a new blank session(same sample rate and bit depth) and try importing Session Data from the bad session. Don't try to do all tracks at once. Try the first 10 or so. If that fails, try the next 10. If that works, keep importing(SAVE after each successful import of some tracks). If you get lucky, you may recover enough(but expect at least one track will refuse due to file corruption). If the above fails, step #2-create a blank session at a different sample rate(IOW, if original is 48K, make the new session 44.1K). Then use Import Session Data and check the box to apply SRC(Sample Rate Conversion). The thinking here is; re-writing all the audio files to a new sample rate MIGHT work(it has for me, twice in the last several years).
the document could not be opened because it was created with an older version of P T | postpro | Pro Tools TDM Systems (Mac) | 1 | 07-27-2013 07:33 AM |
the document cannot be opened because it was created with an older version of PT | studer80 | Pro Tools 10 | 7 | 01-02-2013 06:00 PM |
The Document cannot be opened because it was created with an older version of Pro Too | dmartin714 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-16-2010 07:28 AM |
The document could not be opened because it was created with an older version of Pro | Santiagoc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-13-2009 05:06 PM |
