Old 11-17-2003, 10:24 PM
ixnys ixnys is offline
Default Nothing is record enabled yet I\'m hearing my mics!
I'm using Pro Tools HD and I've been trackings drums and therefor are using 10 analog ins. This is crazy, but it seems like sometimes in this case analog ins 5 and 6 are coming out of my speakers even though they are not record enabled. I can't understand how this is happening. Has this ever happened to you...anybody know how to fix this. I don't think this interferes when I record onto the tracks, but it is annoying and I would like to get to the bottom of it.
Old 11-17-2003, 11:12 PM
Rail Jon Rogut Rail Jon Rogut is offline
Default Re: Nothing is record enabled yet I\'m hearing my mics!
Do you have any hidden Aux tracks?
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 11-18-2003, 12:00 AM
Wyn Wyn is offline
Are you using a console to feed the ProTools inputs?
When you MUTE those two tracks, do you still hear the audio?
If not, refer to Rail's message.
If so, try this.
Save your work.
CTRL Click the left column of the ALL group to show everything.
Select everything. (Alt click on any track name)
Hold down Shift+Alt and select voice off on any track, (this will turn voices off on all tracks).
Do you hear it now?
If you do, then I doubt what you hear is coming from ProTools.
If not, enable each track's voice one by one.
This should reveal the culprit.
Wyn Davis - Total Access Recording Studios
Redondo Beach, California
Old 11-18-2003, 09:00 AM
Extreme Mixing Extreme Mixing is offline
Rail
It's easy for this one to happen, especially when you get the session from someone else, and don't know what they were using. Maybe an external reverb return...
Steve Shepherd
Extreme Mixing
Old 11-18-2003, 09:28 AM
Yeah, I have muted ALL of my tracks and still I'm picking up analog ins 5 and 6 which are two of my tom mics. I have record enabled everything and muted everything...I still hear those mics emitting sound out of my monitors. I have gone into my I/O setput and made sure everything is correct. Just really weird.
Old 11-18-2003, 10:00 AM
Drew Mazurek's Avatar
sounds like a prefader send is active somewhere.
www.drewmazurek.com
Old 11-18-2003, 10:02 AM
Create a master fader for your Tom tracks and see if you have post fader metering on it.
Rail
Platinum Samples
Old 11-18-2003, 04:34 PM
Wyn Wyn is offline
Just wondering, do you also hear these mics after you QUIT Protools?
Old 11-18-2003, 06:43 PM
haven't tried that
MIDI record enabled and found but wont record BCRich 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-23-2010 12:51 PM
Having a problem hearing audio on record enabled tracks riffmachine Pro Tools M-Powered (Win) 3 08-26-2007 06:08 PM
hearing everything delayed when I record dtsymxfan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-30-2006 10:50 PM
Buzzing when record enabled vincey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-30-2006 08:46 AM
record enabled? keithbitz Digidesign Hardware & Software 1 06-14-2001 03:07 AM
