PT 10.3.10 and procontrol master meters
I upgraded to pt 10.3.10 and the master meters on the pro control don't work now.
Any ideas? I have searched the forums and find nothing. Thanks Rich os 10.6.8 (but it does it on mountain lion as well. |
Re: PT 10.3.10 and procontrol master meters
Trashed prefs yet?
I have an extra meter bridge if your died Other PC parts as well
If you run the unit thru test mode, do all the meters illuminate ?
Utility/Test/LED |
You might also go to I/O setup and make sure the 'controller meter path' is set to the correct outputs. Sometimes that can change, especially if you're bringing in any sessions created elsewhere.
Yes this! I/O setup Bus tab. as in the top routing in this pic... chris
Master Fader Meters | ZoDMeister | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-04-2009 06:26 PM |
Dissapearing Master out Meters. | WorkingEngineer | ProControl, Control|24, Command|8 | 2 | 12-04-2006 03:03 PM |
Track Meters Vs. Master Meters? | antiphase | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-04-2004 09:33 AM |
PT master level meters, and windows | stoogee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-20-2003 10:58 AM |
Dim meters on ProControl? | 911Turbo | ProControl, Control|24, Command|8 | 5 | 03-22-2000 12:38 AM |
