External Firewire Drive Recommendations
Since I recently installed M-Powered on my iMac, I've been using my internal drive for PT sessions and media. It works OK, but it is my understanding that I should not use the system drive for session files and audio. I am planning to add an external firewire 400 drive for use as audio/session storage. Should I steer clear of 5400 rpm drives? I'm looking at a 120GB FW400 7200 rpm drive that has 2 FW ports, so I can daisy-chain my ProjectMix with it. Is this plan OK?
Bob W. ---------- M-Powered 4.2 iMac 2.16 GHz Intel Core 2 Duo 1GB RAM OS 10.5.3 ProjectMix I/O
Bob W. iMac 24" 2.16 Mhz Intel Core 2 Duo 3GB RAM OSX 10.7.5 MacBook Pro 13" 2.26 Mhz Intel Core 2 Duo 2GB RAM OSX 10.7.5 Pro Tools HD9 003 Rack+ ProControl + Fader Pack Euphonix MC Mix, MC Control |
Re: External Firewire Drive Recommendations
hi,
your plan sounds good. just make sure you drive gets at least 8MB of cache and the FW case as some sort of Ofxord bridge chip. the Oxford 911 support FW400 and IDE, and the 924DSB FW400/800 and SATA drives, like the 10k RPM SATA. Glyph make some good cases. but as long as it´s Oxford in it all is fine. best
last: PT11.3.1 |
I'd look into these. Reasonably priced, and lots of guys around here have had good luck with them:
http://eshop.macsales.com/shop/hard-...te-al-pro-quad J |
Thanks. I found one of those great deals on eBay. It's a Fantom Drives enclosure with a 7200 rpm 120 GB drive with dual FW400 ports. Got it for $10 plus another $10 for shipping. Seems to work fine. Every now and then you stumble across deals like this...
The way around this is to purchase a FW card, either for a slot in your G5/Mac Pro or, in my case, a card for my MacBook Pro. This puts the INTERFACE and DRIVE on a totally separate data path and will give you the best performance. Again, there's not much you can do with an iMac. Other World Computing (macsales) is a GREAT place to get drives. Look at the Seagates more than anything else. They are worth the minimal cost difference!!
Eric Seaberg • San Diego, CA A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S. |
XP firewire PCI/External drive recommendations | MrGarbage | Pro Tools M-Powered (Win) | 1 | 01-04-2010 07:09 PM |
External Firewire Drives Recommendations for 002? | Jay Terrien | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 05-11-2005 09:34 AM |
External Firewire DVD Burner Recommendations | COCO | Pro Tools TDM Systems (Mac) | 0 | 09-29-2004 07:41 PM |
External Firewire Drive Recommendations? | bounce88 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 19 | 01-27-2004 02:15 PM |
external firewire recommendations | Dopamine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-06-2002 07:58 AM |
