Old 09-08-2020, 04:36 PM
MLaudio MLaudio is offline
Default Shortcut to disable all plug-in automation from plugins?
I was wondering if there is away to do this on all plug-ins in a session quickly? I use to leave "plugin controls default to auto enable" always checked (despite not using a lot of automation) and eventually discovered that that was the cause of bugs within Pitch II, Dverb and EQ7. I now leave it unchecked and only select the parameters i want to automate when needed. However, i have a ton of sessions that i still access that had the auto enable checked initially. Turning it off doesn't remove it from the existing plugins (only future ones). I find it tedious going through each plugin, clicking the two little boxes up top, selecting all the parameters and removing them. I was wondering if there is a quicker way to remove all parameters from all the plugins in a session? Any help or info is appreciated :)
Old 09-08-2020, 09:59 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Shortcut to disable all plug-in automation from plugins?
I don't know of a way to remove all the plugin automation parameters for all the plugins in a session at once, but if you open any plugin window and Command+Option+Control-click (Mac) or Control+Alt+Start-click (Windows) on the Auto button at the top of the plug-in window, it will enable/disable all plug-in parameters for that plugin. At least it would save you a few steps.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 09-09-2020, 07:36 AM
That is great man! I knew about that hot key for enabling and disabling single parameters but never tried it on the 2 little boxes. That will definitely help with saving some time. I really appreciate it.
Old 09-09-2020, 05:45 PM
cwsand's Avatar
No problem - glad to help!
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
Shortcut To Disable All Plugins lesbrunn Tips & Tricks 29 01-29-2018 07:24 PM
Turn Automation on shortcut (CRTL+OPT+CMD+Click) not working with UAD Plugins? DJ Hellfire Pro Tools 12 3 02-14-2017 09:17 AM
Shortcut to Enable/Disable Plug-ins ??? russrags Windows 2 01-09-2016 12:24 PM
Copy special Plug-in automation shortcut simonyeah Post - Surround - Video 1 07-12-2010 04:41 AM
Plug-in Automation Shortcut Plugs Tips & Tricks 0 10-16-2003 12:12 PM
