Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 04-05-2010, 04:36 AM
patch morrison patch morrison is offline
Default Audio Units seem to replace default plug ins
I just installed Guitar Rig 2 (which I previously used with Logic).
It still comes up in Logic under my audio units section with no problems, but in PT it pops up under every plug in type!!
On mono tracks (pictured here), it appears in the EQ section after the various different EQ types (default ones), on a stereo track (pictured here) it seems to have replaced EQ!!
It behaves the same for compession, reverbs, pitch shift etc...
I'm sure there is some behind the scenes disc allocation or something I need to implement to make the audio unit appear its own separate category but I am yet to find it.
any ideas?
cheers,
Patch
Old 04-05-2010, 11:15 AM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
Default Re: Audio Units seem to replace default plug ins
All ProTools plugs are setup MONO or STEREO (also DUAL-MONO). What you're seeing is normal.
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
Old 04-06-2010, 02:19 PM
clausiii's Avatar
clausiii clausiii is offline
but GuitarRig is not an EQ plugin. So it has not to be in that section. TL Space has an EQ (kind of) and is not in the EQ section....
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Default patch settings? Drag & Drop replace sample? Farmer Dave Virtual Instruments 8 02-28-2008 06:22 PM
Audio Units and PT 6.4.1? Violin Vienna Digidesign Hardware & Software 0 02-09-2008 12:24 AM
freeware audio units plug-ins? Bendrissa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 03-31-2004 03:28 PM
Audio Units, Core Audio, and the Powercore Firewire Box deepdownlow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-31-2003 12:00 AM
Will the core audio driver enable audio units ? linpaws 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-16-2003 02:01 AM
