Moving all protools and reason software, plugins, files from old mbp to new mbp?!?
I'm running M-audio firewire 1814 with PT Mpowered 7.1.1 and reason on my old macbook pro Hardware Overview:
Model Name: MacBook Pro 17" Model Identifier: MacBookPro2,1 Processor Name: Intel Core 2 Duo Processor Speed: 2.33 GHz Number Of Processors: 1 Total Number Of Cores: 2 L2 Cache (per processor): 4 MB Memory: 2 GB Bus Speed: 667 MHz Boot ROM Version: MBP21.00A5.B08 SMC Version: 1.14f5 Serial Number: SystemSerialNumb Sudden Motion Sensor: State: Enabled I have a bunch of plugins installed, and loads of half finished projects, and my mac is beginning to collapse under the pressure of trying to run it. I don't have the original installation discs for any of the programs, and I was told by a mac rep. that I can just buy a new machine and transfer everything, programs and all, onto it. This just sounds too good to be true, and I envisage all sorts of compatibility issues moving programs from OS X 10.4.11 to the latest version of snow leapard... Is there anyway I can complete this task and be assured I won't have to re-install anything? Even plugins etc? Can I really just plug a new machine into my old one and transfer everything and it will work perfectly? Please forgive my cynicism, and my lack of knowledge in this area, if anyone needs more info please ask. Any help / guidance would be greatfully appreciated, Thanks in advance, Ant |
Re: Moving all protools and reason software, plugins, files from old mbp to new mbp?!
as far as i know you can connect 2 macs setting one as target disk mode using t as hd the transfer everything to your new one and maybe you'll need to reinstall only a few things, or you can use an external hd, and another way is to transfer from another mac when you're installing the new os on the new machine.... but probably the best way is to set a mac as target disk mode...on system preferences/start up disk...target disk mode
Hi thanks for that, I was also thinking it would be better to use Target Disk mode instead of the migration assistant - I read people seem to have more trouble with it that way.
I'm more worried about losing the plugins I suppose, I've read threads where people have moved plugins from one laptop to another and then they need re-authorizing etc. If there is anything I can do to make sure it all goes smoothly, I'd love to know!! Thanks |
super duper google it.
WENT FROM HD TO M-POWERED
Moving RTAS plugins folder - ProTools 10 | thghgv | Windows | 5 | 05-27-2013 07:46 PM |
Timecode Bits...Moving files from other DAW's to Protools | TCLguy1 | Pro Tools TDM Systems (Mac) | 4 | 02-09-2010 02:06 PM |
Moving protools files: recording and backup: whats your setup? | T-Diddy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 01-12-2010 05:24 PM |
Moving MIDI from Reason to PT-Is it possible? | nicksorenson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-03-2009 03:14 PM |
software appears to let you use VST plugins in ProTools LE | Slaterman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-04-2001 09:46 PM |
