? Source of Mystery Blue-Line Volume Automation
I rely quite heavily on VCA volume automation to control grouped tracks. When VCA Volume Automation controls a group in which a given track resides, that track's volume automation is written with the traditional Black line, with the VCA Volume automation impacting that track rendering as a Blue Line in the Volume Automation lane.
In a large current session, I have mystery volume automation showing as a blue line over a dozen or so tracks. The blue line is nutso huge sawtooth volume swings over certain timeline sections. No VCA controlling those tracks shows volume sawtooths, and there is no Trim Volume sawtooths in either the audio tracks affected, or in any VCA. It's as though there is a hidden VCA that applies to the affected tracks, and that the VCA has sawtooth volume automation. When I display only VCA Masters in the track window and observes the VCA tracks, there is now sawtooth movement. What gives here, please? John Caldwell
Pro Tools 2018.4 HDX, 192 and Lucid I/O 5,1 MacPro 12 Core; OSX 10.12.6 |
Re: ? Source of Mystery Blue-Line Volume Automation
Composite Playlist.
View menu/Automation/Composite Playlist Pg. 1105 of ref manual. |
Thanks Drew. The Blue Line automation, crazy as it appeared, disappeared when the VCA channels that controlled those tracks was deleted. Even it retrospect, neither the VCA's Volume or Volume Trim automation explained the radical Blue Line data.
Thanks very much. John Caldwell
Go through the manual, it'll all make sense once you play around with it a bit. |
Get that. What didn't make sense is that the VCA's automation was quite modest in its volume shifts. The Blue Line was crazy saw tooth that went from negative infinity to positive 8. We have the option of Coalescing VCA automation, or not, at the time of deleting the VCA track, or leaving the VCA in place by Right Clicking the VCA. I use those features heavily.
Thanks for your kind assistance, Drew. John-
Blue line when doing volume automation [solved] | Harliraha | Pro Tools 10 | 17 | 05-05-2015 09:23 AM |
What is the blue line in volume on the edit screen. | P,B,S | Pro Tools 10 | 7 | 06-02-2013 12:00 PM |
Default Source for Bounce to Disk Mystery | Neesley | Pro Tools 9 | 2 | 02-09-2011 01:57 AM |
Why is blue line overriding volume automation? | spiritG | Pro Tools TDM Systems (Mac) | 3 | 09-05-2010 11:53 AM |
Lighten edit window and thicken the volume automation line | Sukram | Pro Tools TDM Systems (Mac) | 26 | 12-09-2009 12:18 AM |
