Dolby E layback to a SWR-5500 Need Tri Level?
Hi All,
Quick question. If I am laying back a Dolby E data stream to a SRW-5500, do I need to be locked to tri-level if the frame rate is 29.97 drop? I think I only need tri-level sync when I layback to 23.98. Is that correct? Thanks for the help. Best, Brandon |
Re: Dolby E layback to a SWR-5500 Need Tri Level?
Ultimately, you need to be locked to whatever the deck is locked to. But your thinking is correct: standard black burst is fine for laying back to HDCAM at 29.97.
Thanks. I just didn't know if a dolby e data stream had different requirements then standard digital audio.
Best, Brandon |
If you are laying back a pre-encoded Dolby E stream, it is just PCM audio that happens to be a Dolby E stream. The deck just needs to be synchronized. Tri-level sync does need to be used with Dolby E hardware encoders in certain situations for it to properly sync.
Thanks Paul. That's why I asked the question. The studio is locked to black but hasn't upgraded to tri-level yet.
Best, Brandon |
SRW-5500 layback problem | bdangler | Post - Surround - Video | 7 | 05-08-2010 09:35 AM |
SRW 5500 Lines 18 to 48 Dolby E what the HE!! | not2tech | Post - Surround - Video | 4 | 04-22-2010 09:34 AM |
Dolby E layback to srw 5500 2 frames advance? | not2tech | Post - Surround - Video | 10 | 03-31-2010 12:38 PM |
? about sony 5500 and dolby E | not2tech | Post - Surround - Video | 8 | 02-26-2010 09:41 PM |
OT: HDCAM SRW 5500 layback problems (latency!) | Matt Chan | Post - Surround - Video | 4 | 05-16-2007 10:43 AM |
