Missing DSP plugins and Engine setup is wrong
We have 2 ProTools HDX mac systems running identical versions of
ProTools 10.3.10. Recently one of them is not showing dsp plugin options and I get this error message when opening a project: If I go to setup to change it these are the options: See how it says "Avid HDX" In the other system that is working, the option is called "HDX" there is no Avid preceding it. and the "HDX" is at the very top, not near the middle like this one. Is there any way to fix this? I did try trashing preferences and that did nothing. I know the hardware is ok, because if I boot up from a recent backup system disk, everything is ok like the other system. I'd hope to fix this instead of having to wipe and reclone the system disk. thanks! |
Wrong inputs and incorrect error about playback engine sample-rate support. | Mark Kieviet | Pro Tools 11 | 7 | 10-27-2016 02:11 PM |
Playback engine always wrong | Sir Hannes | Pro Tools 12 | 4 | 12-04-2015 12:45 AM |
Wrong number of cores displayed in Playback Engine Dialog | delorian | macOS | 6 | 06-25-2012 10:15 AM |
What am I doing wrong in the Playback Engine | arb232 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-15-2010 07:07 PM |
"Edit MIDI Setup" Setup Menu Item is Missing! | altemir | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-08-2004 12:24 PM |
