Automation Snapshots
Is there a way in ProTools to save more than one automation snapshot? I know you can save several when using a D-Command, is this feature available to those without a D-command?
Re: Automation Snapshots
Hi
Make a selection or select the clip or tracks where you want to make a snapshot. Now with keys or from the menue do "Write to current or write to all enabled". This way you can have as many snapshots as you need. Just look at the menue to see what options you have Ale
2 PT HD Ultimate 2023.12 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1) 1x PT 2023.12 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+ |
That's not quite what I am talking about. Using the Capture button on the automation window you are able to store all of your track parameters into a capture buffer. This includes all of your plugins, panning, level, etc. You can then punch those parameters into different selections wherever you choose. With a D-command you are able to save these capture buffers... I believe up to 48 snapshots.
Useful when you have the same scene come up at different times. |
Do you mean going back to a selection, were your desired automation is; Alt+Capturing it, and punching that to a new selection ?
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
Why is it not so good to copy special all automation of the previous scene and paste special/repeat to fill to the following same scene ?
(Just want to learn)
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 Last edited by joachim; 07-22-2013 at 02:34 PM. Reason: forgot what |
You can´t.
Buy artist control, you´ll get 48 snapshots on it. |
Oh really? Thought that was only for D-Command and D-Control. Good to know.
Well, If I wanted to just copy an EQ setting, I would Command+Shift+C and paste it, but I want to copy the EQ, Panning, and Aux levels, you can Option+Shift and click capture and then option+shift punch at the desired place.
I need to experiment with Alt+Shift+Capture befor asking any new question ... .
You just made my day. I've been searching online for this specific feature and finally found it. Thank you sooooo very much!!!
Automation snapshots? what are they? how to? | postprosound | Post - Surround - Video | 4 | 04-10-2007 08:43 AM |
Automation Playlists & Session Snapshots | Mount Royal | Pro Tools TDM Systems (Mac) | 10 | 09-04-2006 06:04 AM |
Notion: Automation Playlists & Session Snapshots | Mount Royal | Pro Tools TDM Systems (Mac) | 0 | 08-15-2006 06:19 AM |
plugin automation snapshots possible? | Mark Dann | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-12-2002 06:02 AM |
Automation questions - Trim and Snapshots | Psonic Psunspot | Tips & Tricks | 2 | 12-27-1999 12:16 AM |
