Old 04-11-2021, 06:00 AM
huzzam huzzam is offline
Default How to control Soundtoys parameters via MIDI?
Hi everyone,
I'm trying to use an expression pedal connected via MIDI to control the Feedback in EchoBoy, so i can write automation of this parameter while recording. SoundToys plugins don't support right-clicking to map controls (as, e.g., the Waves H-Delay does). Is there any way built in to PT to map incoming MIDI CCs to a given automation parameter?
FYI my expression pedal is connected through a MorningStar MC6, which is set up as a MIDI Input Device in PT.
Thanks!
* Macbook Air : M1 ~ 16gb ~ 1tb ~ Ventura latest
* Hackintosh : i9-9900k ~ 16gb ~ 3tb ~ Monterey 12.6.1
* PT 23.6 + Ableton Suite 11.3
* Soundtoys + Valhalla + Fabfilter + Spitfire
* RME Fireface UCX II ~ Arturia Keylab Essential 49
* various clarinets, trumpets, flutes, plucky stringy thingies
Old 04-11-2021, 06:16 AM
JingleDjango JingleDjango is offline
Default Re: How to control Soundtoys parameters via MIDI?
If you pick up a Eucon control surface this becomes trivial. Try the used market if the current offerings are out of budget.
Old 04-11-2021, 07:19 AM
ha, thanks for the suggestion... that's a bit more "heavyweight" than i was hoping to go. I can already record the expression pedal data into a MIDI Track, but I can't figure out how to route that to the automation lane of a plugin in realtime. Surely there's a way, without needing extra equipment, yes?
I've tried setting the output of the MIDI track to the various EchoBoy channels in the output selector, but none do anything.
(Of course, i can copy-paste the automation data from the MIDI track to the relevant automation lane after the fact, but that doesn't give me the ability to "perform" the automation as i'm tracking.)
Old 04-11-2021, 08:10 AM
clausiii's Avatar
clausiii clausiii is offline
Hi!
it only works if you have a MIDI controller enabled in the Peripherals/MIDI Controllers dialog. Then in the plugin windows you will find MIDI mapping options in the top area of the plugin window.
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 04-11-2021, 11:33 AM
Thanks for the response! but I'm not finding any midi mapping options in the top of the plugin window. There are automation options, but i don't see any way to link those to a midi controller. I'm probably just being an idiot, but can you help me understand how this should work?
Old 04-11-2021, 12:51 PM
Sardi Sardi is offline
I don’t believe Soundtoys plugins support MIDI learn.
Not at the studio, but can check for you when I am there later today.
Old 04-11-2021, 02:08 PM
clausiii's Avatar
The mapping options appear when you setup a Midi controller in the Peropherals Dialog in Pro Tools
Then you can midi learn all automateable parameters.
My ears! My ears!
clausiii
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 04-11-2021, 02:15 PM
They don't as far as I can see.
Jack
QAPLA!
Old 04-11-2021, 03:11 PM
Yes, but only if the plugin in question supports MIDI learn within PT. I don’t believe Soundtoys does.
Old 04-11-2021, 03:13 PM
Yeah, from memory they don’t.
I use Eucon to control them, so it’s been a while since I tried MIDI, but IIRC, they don’t work via MIDI in PT.
Control Plug-In Parameters with a MIDI control surface b1daly Tips & Tricks 8 03-26-2023 09:29 AM
Do you think we'll ever see generic MIDI Control of plug-in parameters? weezul Pro Tools 12 17 02-27-2016 05:21 AM
Midi Control over Plug-in parameters help... breaktheory 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-11-2010 03:55 PM
Control Reason parameters via PT MIDI automation? Pulque 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-23-2004 06:36 PM
control plug parameters via MIDI Slink General Discussion 0 05-17-2003 07:47 AM
