Old 05-09-2017, 08:36 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: D-Command - track name
Originally Posted by Drew Mazurek View Post
So, it's specific to that track.
Try making new session and importing that track.
Try changing that track's name.
yes good idea...thanks.
Originally Posted by Stig Eliassen View Post
Have you replaced the name with a space? The strip will turn black if so.
no i haven't changed the name....I will try the rename....thanks guys.
Daniel
Old 05-10-2017, 08:47 PM
YYR123's Avatar
Well the reset didn't work, I forgot to rename the track ....once I get in the session I am focused on other things
I will get it
Daniel
Old 05-11-2017, 07:48 PM
Barry Johns Barry Johns is offline
Try moving that track to a different location on the mixer, see what happens then.
Move it between Voz and VZVERB
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
Old 05-12-2017, 04:59 AM
Drew Mazurek's Avatar
See post 6.
http://duc.avid.com/showpost.php?p=2429608&postcount=6
www.drewmazurek.com
Old 05-12-2017, 09:22 AM
I'm suggesting something completely different. Nudging/banking keeps all the tracks in thier current order. I'm suggesting moving the individual track to a different location.
  #16
Old 05-12-2017, 09:29 AM
got it!! I wonder what will be the fix!! stay tuned!
www.drewmazurek.com
  #17
Old 05-12-2017, 09:58 AM
YYR123's Avatar
So I didn't figure it out, but happened to Commit my track and the committed track shows fine
Let me tell you something else weird,,,,
But watch this
After pressing insert and then the select (lower encoder) it shows....
Daniel
  #18
Old 05-12-2017, 10:00 AM
YYR123's Avatar
But it doesn't stay, it's like it tells me I am going to put an insert on that channel but then when I back out of the insert Command it disappears again
Daniel
  #19
Old 05-12-2017, 10:01 AM
YYR123's Avatar
Idk I've given up, it's obviously the track b/c the committed version is fine....
Daniel
  #20
Old 05-12-2017, 10:24 AM
send me the ptx file, no audio.
let's see what it does here.
www.drewmazurek.com
D-Command Track Select antonis Post - Surround - Video 4 07-21-2014 02:19 PM
Key Command for next track selection ? Firechild Pro Tools TDM Systems (Mac) 6 06-23-2012 12:43 PM
Command 8 Track Banks mman00 Pro Tools TDM Systems (Mac) 2 02-15-2011 07:32 AM
"select next/previous track" "rec enable track" key command? maufau Pro Tools TDM Systems (Mac) 6 04-22-2008 05:08 PM
Track 1 on Command 8 going all over the place... Rated R ProControl, Control|24, Command|8 0 03-17-2007 11:10 AM
